0 Members and 74 Guests are viewing this topic.
Hope
Quote from: wattsup on November 02, 2011, 01:08:57 PM
@bender
The links are all over the place. This is why we need one @member to do the following;
1) Contact @hartiberlin who is the forum administrator and ask him for permission to open a new companion thread to this one with moderator status and ability to lock the thread.
2) Open the new thread that can be called "Tariel Kapenadze" -
"Companion Thread", or,
"Tool Box", or,
"Compendium", or whatever.
3) Start post #1 as a Table of contents that has links to the main thread with a brief description of the link.
4) Put a link to the new thread in your profile signature so other @members can have access to it if it flies off recent posts page.
5) Once and a while post something on the main thread to keep your signature accessible on the main thread.
We need this to keep track and to enable anyone else who arrive here an easy method of getting up to speed.
I personally do not have the time to do it myself and hope that some @member will take up the challenge. So please all, let's get back on track.
wattsup
Wattsup could you begin a PDF download (locked from changes cep by you) and keep it updated as much as needed?  The reason I ask you is because of your knowledge from the builders point of view and your keen interest.  Even past all that is that your comments are respected by others, even those who have been here far longer.  You are able to keep on topic and not get emotionally insolvent as well.  This project is far reaching and your maturity is needed to head the documentational aspect to provide the correct build guidelines to keep us congruent.  This will keep us from wasting monies and our valuable time.  Will you take this responcibility?  Thank you.
Edited as such:   T-1000 and Wesley Group  can you formalize your lab notes into useful documentation?  Please describe each point twice so we can insure a correct understanding.
Thus far all we have are gleanings and a nice cad drawing that is incomplete as a whole schematic.
A solid parts list WITH part numbers would be best.
AND thank you ALL for your many efforts to get us to this day.
ANYONE on the forum good with PowerPoint or like program, even MS Movie or likes program could edit shots for a led build tutorial.  This would be great seeing as the many non english speaking builders we are gaining here.
stivep
YOU WANTED COMPLEX INFORMATION IN ONE PLACE ...SO THIS ONE IS LOOOOOOOONG BUT PROVIDING WITH MOST OF DETAILS THE REST WILL BE DONE BY ARUNAS
Note that steps of me and Arunas  differ a litle that is because of personal experience between  to of us. Do not disregard Arunas  notes ( post below my post) both approaches should give you desired effect
Quote from: grizli on November 03, 2011, 04:06:30 PM
I will connect my questions with yours
WILL device work if 50hz and 386khz are NOT synced ?
IT WILL NOT.. THE FREQUENCIES ARE NOT ALWAYS THE SAME as properties of ferrite are not the same.
I have got ferite cores  just few minutes ago... American made and  will attempt to check them out. I have 6 of them  two of them are different.. the ferrites are in different shape more cylindrical and just smaller.. I have paid $5  per one. plus $28 shipping charges.
Do not count on fixed frequencies..  The whole process is not that easy as it looks like..
1 . connect  50 winds  to Vector Network Analyzer output
2 . connect  (ekran) shield / cooper strip winding  to output.
3 .analyze  if you see pick on 1.2Mhz to 1.8 Mhz
4 .than connect  generator with square or  ramp at frequency of pick say 1.3 MHz to    (ekran) shield / coper strip
than tune it left right  to maximum amplitude of 50 winds ( OSCILLOSCOPE AT OUTPUT)
5. than read the frequency  and voltage on 50 winds ( OSCILLOSCOPE AT OUTPUT)
6. than connect generator to 50winds with frequency of readout
ALL OF THE STEPS SHOULD BE DONE  WITH ONE GENERATOR ONLY!!! AT THE TIME..
7. tune that generator to maximum voltage on bifilar output.( OSCILLOSCOPE AT OUTPUT + hv probe)
8. than connect second generator to 15 winds  at starting frequency of 50 Hz ,and tune it to maximum at bifilar
9.connect flyback to  (ekran) shield / coper strip winding and give one spark only
10. see the response on oscilloscope  and/or light bulb at bifilar output.
11. re tune circuit  with two generators readjustment//
method #2
instead of point 1.
connect generator  square to 50 winds
and connect spectrum analyzer at  (ekran) shield / coper strip winding
look for  more than 1MHz pick..
than fallow the other   points of  instruction
ARUNAS:
5 minutes ago correction from Arunas:
quote"[4:47:10 PM] Arunas point # 3 ."analyze  if you see pick on 1.2Mhz to 1.8 Mhz" -> see where is peak on spectrum analizer when white noise is fed into copper plates"
[4:49:14 PM] Arunas point#: 5. than look for lowest harmonic resonant frequency  of 50 winds coil with highest amplitude ( OSCILLOSCOPE AT OUTPUT)
[4:51:00 PM] Arunaspoint#: 8. than connect second generator to 15 winds and tune it to maximum at bifilar
( OSCILLOSCOPE AT OUTPUT). It should be low frequency around 50Hz. Look for best match between 2 frequencies so low frequency will be carrier of 51 turns coil frequency(in our case it was 47 Hz)
[4:53:15 PM] point#: 9.connect flyback circuit with spark gap from our first experiment schematics to copper plates and tune variable capacitor attached to copper plates for maximum output.
[4:54:34 PM] Arunas Note: this most likely will heat up ferrite core and destroy it after 15-20 minutes
[5:00:47 PM] Arunas Note#2: Arunas -Note#2:"  -For impedance match you will probably need unwind secondary coil or wind more wire on it. The method determining that is: if you touch with one of secondary coil wires with finger or additional wire which would be as antenna and see more bright halogen, you need more turns on secondary. If halogen bulb brightness fades, you need less turns on secondary coil.
Note from Wesley:
if you have impedance meter  that  is capable  of choosing particular frequency and or display impedance at desired frequency (50 ohm between output of commercial generator.. than connected winding will be a load to the generator  in such way that after bifilar is connected with load than you measure impedance with
a- generator disconnected and impedance meter connected to 50winds winding than 15 winds winding NO POWER!!!!!!!!!!!!! NO signal delivered!!!!!!!!!!!but light bulb connected!!
b- you can also try to take few meters or bundle of wire and instead of inactive test make test on load you either cut the wire  piece by piece or  play with  variable capacitor in series with the wire.. only one end of wire should be connected to say (15winds)(in my case16 wind winding)
Note#2 from Wesley:
that what Aidas called copper plates = what I called (ekran) shield / coper strip winding
Note#3 from Wesley
The confusion about impedance:
Explanation.
12.
electrical impedance is:http://en.wikipedia.org/wiki/Impedance
-the ratio of the voltage phasor to the electric current phasor, a measure of the opposition to time-varying electric current in an electric circuit
Wave impedance is:
-, a constant related to electromagnetic wave propagation in a medium
Impedance of free space is:
-, a universal constant
Mechanical impedance is:,
- a measure of opposition to motion of a structure subjected to a force
( that might be important only for mechanical response of our ferrite to the frequency response in resonance ( hissing sound of ferrite)
or for copper wire vibration:
http://iopscience.iop.org/0022-3727/34/10/315
13. application
a. output impedance of regular commercially available generators is 50 Ohm
b. for impedance match each coil must have 50 ohm impedance
c. when impedance is matched that  capacitive Reactance and inductive Reactance may be uneven  and still you will have 50 ohm of  coil impedance;\
Say  in one scenario
- coil  has capacitive character and less inductive
in  another scenario
coil  has inductive character and less  capacitive inductive
and  still will maintain 50 ohm impedance match..!!!!!!!!!!
when coil character ( LC network character) is capacitive in nature than  it represent higher voltage THAT IS WHAT WE NEED !!!!!!!!!
THIS PART IS IMPORTANT TO UNDERSTAND THE ESSENCE OF HOW TO TUNE COIL.
-every coil is the load to the source.so
15 winds  coil is the load to  generator
50 winds is a load to second generator
but because the coils are coupled to bifilar than their impedance will change when bifilar is introduced and/or paper dividing two halves of ferrite ring
-every coil is RLC network to the feeding device( generator)
Even when not connected  to generators ...coils will have different impedance when load light bulb is connected to bifilar and not yet under power..
You will see that, when ready to use  ferrite ring with light bulb connected is examined and you connect  impedance meter to each of winding 15 or 50 ohm ( in my example 16 and 51)
PLEASE DO NOT SKIP THIS FEW LINKS  AND PLAY WITH CAPACITANCE AND INDUCTANCE IN INTERACTIVE GRAPHYou will understand capacitive  and inductive  dependencies while maintaining 50 ohm.
http://www.intmath.com/complex-numbers/9-impedance-phase-angle.php
go   in the midle of the page  to:
Click where it says "Start"
than play with sliders try to get maximum capacitance and minimum inductance
at 50 ohm and look how voltage and current  lag each other..
look at:25.1 Capacitance and inductance  http://www.lightandmatter.com/html_books/lm/ch25/ch25.html
Phase shift
http://www.intmath.com/trigonometric-graphs/3-graphs-sin-cos-phase-shift.php
go to :Flash Interactive
Play with it.
What we have  access energy from?
go to :http://www.sciencemag.org/content/315/5818/1553.abstract
The current-induced motion of magnetic domain walls confined to nanostructures is of interest for applications in magnetoelectronic devices in which the domain wall serves as the logic gate or memory element. The injection of spin-polarized current below a threshold value through a domain wall confined to a pinning potential results in its precessional motion within the potential well. We show that by using a short train of current pulses, whose length and spacing are tuned to this precession frequency, the domain wall's oscillations can be resonantly amplified. This makes possible the motion of domain walls with much reduced currents, more than five times smaller than in the absence of resonant amplification.
- for pulse density modulation affecting signal  go to :
http://en.wikipedia.org/wiki/Pulse-density_modulation
We are dealing with pulses and pulse modulation as well a density.
for  phenomena in ferrites  go to:
http://scholar.lib.vt.edu/theses/public/etd-543273119623370/etd.pdf
-easy lecture: http://www.chemguide.co.uk/atoms/properties/atomorbs.html#top
- to more advanced who want to understand how copper  ring reacts:
http://www-ceam.ucsd.edu/documents/papers/Smith_PRL_84_4184_(2000)%5B1%5D.pdf
Composite Medium with Simultaneously Negative Permeability and Permittivity
- for these interested with understanding VNA and spectrum analysis easy to read
https://docs.google.com/viewer?a=v&q=cache:P5e_7I3IhAIJ:www.ieee.li/pdf/viewgraphs/receiver_v_sa.pdf+DSI+EMI+Test+Receiver+Model+RX-200+pdf&hl=en&gl=us&pid=bl&srcid=ADGEESjvt8pzw1QgJQxwdgw4F6CA49r2qD0dXmPAJjX_ekiraGmFXlnbIlGLWpDAqE2urqzo3RnpMAFAiGWTQKE58ghHFx4qRU-N6graUB0MsKRtYV1Q02FaPyPAdEi3H2GVcI0Fp3r5&sig=AHIEtbQdcl2lXbt05S0EKdSBNDEgeAjY3g&pli=1
or
Network Analyzer Basics
http://cp.literature.agilent.com/litweb/pdf/5965-7917E.pdf
this is easy do not be discouraged
very important is to understand this material than less questions  I will have to answer
http://www.ece.utah.edu/~ece3300/Labs/lab1/APN1217-1.pdf
2.Basics of measuring the dielectric properties of materials
a.Resistivity
b.Dielectric constant
c.Permittivity
d.Permeability
e.Electromagnetic wave propagation
f.Dielectric mechanisms
g.Electronic and atomic polarization
h.Orientation polarization
i.Ionic conductivity
j.Interfacial or space charge polarization.
3.Measurement systems
a.High resistance meters
b.LCR meters and impedance LCR meters
c.Network analyzers A measurement of the reflection from and/or transmission through a material
Resonant transformers:
For more details on this topic, see Resonant inductive coupling.
A resonant transformer is a kind of leakage transformer. It uses the leakage inductance of its secondary windings in combination with external capacitors, to create one or more resonant circuits. Resonant transformers such as the Tesla coil can generate very high voltages, and are able to provide much higher current than electrostatic high-voltage generation machines such as the Van de Graaff generator.[52] One of the applications of the resonant transformer is for the CCFL inverter. Another application of the resonant transformer is to couple between stages of a superheterodyne receiver, where the selectivity of the receiver is provided by tuned transformers in the intermediate-frequency amplifiers.
For these who is not familiar with practical electronics:
http://web.hep.uiuc.edu/Home/sibert/NEETS/Mod14.pdf
this material is only for purpose of HOW TO BUILD  VARIABLE TUNING CAPACITOR HV?
http://www.coe.ufrj.br/~acmq/bennetd.html
http://www.coe.ufrj.br/~acmq/svanberg.html
this is interesting material I have to get closer to it:
http://www.falstad.com/circuit/e-gyrator.html
it might be applicable . logic might be the simpler way to  create tun-able generators.
Simulating Electromagnetic Interactions in High
Power Density Converters look at  drawings
http://www.stefan-peter-weber.de/publikationen/pesc05.pdf
PERMANENT  MAGNET  AIR-CORED  TUBULAR  LINEAR
GENERATOR FOR MARINE ENERGY CONVERTERS
http://eprints.lancs.ac.uk/20104/1/getPDF.pdf
look at drawing and power factor notes.
Figure 5 :  Axial force verses position for constant current
Figure 7: Tubular Machine Translator !!
Figure  12: Comparison  of predicted  and experimental voltage
for a  17 Ohm load
9.  Conclusion
An Introduction to Barkhausen  +44 (0)1981 541122
Noise and its Applications
http://www.insight-ndt.com/papers/technical/t013.pdf
1.1.6 Irreversibility
With magnetic types of inspection and phenomenon there is an aspect that one
frequently encounters.  The aspect of irreversibility is displayed in a ferromagnetic
material’s inability to return to the original magnetic state.  In other words, once a
ferromagnetic material has been placed in a magnetic field and taken from the field,
there will remain in the material some amount of residual magnetism.  This
characteristic occurs on the order of the individual magnetic domains within a
material, thus causing a very unrepeatable transition when the magnetic field is changing within a material.
What night be happening to the ferrite:
Chapter 10: Phase Transformations in Metals
http://www.virginia.edu/bohr/mse209/chapter10.htm
Former Army secrets:
EVALUATION OF DEVELOPMENTAL  HIGH TEMPERATURE
PULSE FORMING  NETWORK,  Z-2922
MANUFACTURED  BY  SPRAGUE ELECTRIC COMPANY
NORTH ADAMS, MASSACHUSETTS
http://www.dtic.mil/cgi-bin/GetTRDoc?AD=AD296129&Location=U2&doc=GetTRDoc.pdf
look at :
4.  Comparing the  standard AN/APS-45 pulse-forming network  in the modulator circuit with the  sample network  indicated that the parasitic
oscillation was present only in the  sample network.  Principally, parasitic oscillations result from impedance mismatches.  Many times these
mismatches  are  caused by stray  inductances and capacitances.  In this
particular  case where  the active volume of the network was  reduced by
the  incorporation of  the expansion  compartment, it  is possible that  the,,,,
(read  to the rest of it)
Radars have been modulated by spark gap:
Q-16. What is nonpulse time?
Q-17. What is average power in a pulsed system?
RADAR MODULATION
http://webcache.googleusercontent.com/search?q=cache:s-qkG0b98GsJ:www.tpub.com/content/neets/14184/css/14184_127.htm+pulse+forming+network+radar&cd=3&hl=en&ct=clnk&gl=us
RADAR MODULATION#2
http://webcache.googleusercontent.com/search?q=cache:j9gRgVj_CxMJ:www.tpub.com/neets/book12/49i.htm+pulse+forming+network+radar&cd=2&hl=en&ct=clnk&gl=us
This is how   pulse- forming network is made
http://webcache.googleusercontent.com/search?q=cache:wm4kGUKawVEJ:www.radartutorial.eu/08.transmitters/tx06.en.html+pulse+forming+network+radar&cd=1&hl=en&ct=clnk&gl=us
Figure 3: charging currents path
PULSE FORMING NETWORK (PFN) FORMULAS
look at:Type A PFN and drawing below
http://www.nessengr.com/techdata/pfn/pfn.html
Practical explanation and advise to standing wave and terms used by ARUNAS
NODE AND ANTINODE
http://www.intuitor.com/resonance/standingEwaveDemo.html
Standing wave:
http://amasci.com/freenrg/audwall.html
Materials:
-take deflection yoke from old TV  the one that is on the CRT tube  take ferrite out of it by  puling gently snapping spring brackets out
-wire 18 gauge 50 winds in plastic insulation recommended
-wire 18 gauge 15 winds in plastic insulation recommended
-wire 18 gauge 150 winds x2 bifilar  (in plastic insulation recommended)
- HV transformer ( no diodes build in!!!!) make sure that in plastic coil there is no diodes molded and you have access to windings of transformer directly
deflection yoke and ferrite  cores for it:
everything about it
http://www.oddmix.com/spec/mag_yk_e70954s.html
https://www.google.com/search?aq=f&gcx=w&sourceid=chrome&ie=UTF-8&q=Deflection+yoke+cores#q=Deflection+yoke+cores&hl=en&prmd=imvns&ei=9X-tTpPxPIrq0gGps4y7Dw&start=20&sa=N&fp=1&biw=1254&bih=869&bav=on.2,or.r_gc.r_pw.,cf.osb&cad=b
http://repairfaq.ece.drexel.edu/REPAIR/F_tvfaq6.html#TVFAQ_001
http://www.esuppliersindia.com/b-l-k-ferrites-pvt-ltd-/deflection-yoke-core-pr255703-sFP-swf.html
http://www.fdk.co.jp/laboratory/ce_hon-e.html
http://scitation.aip.org/getabs/servlet/GetabsServlet?prog=normal&id=DTPSDS000029000001000343000001&idtype=cvips&gifs=yes&ref=no
http://www.tradekorea.com/e-catalogue/youngjin87/product-detail/P00020917/Series%20For%20Deflection%20Yoke%20Core(ceramic).html#
http://www.chinadmegc.com/chinadmegc/english/web/about3_202.asp
Anything more in another book :)
Wesley
grizli
Quote from: stivep on November 03, 2011, 04:36:15 PM
method #2
instead of point 1.
Note from Wesley:
a- generator disconnected and impedance meter connected to 50 ohm than 15 ohm NO POWER!!!!!!!!!!!!! NO signal delivered!!!!!!!!!!!
Wesley
IN all this method I do NOT see any syncronisation method to get synced frequencies :
Definition : Two signals are  in sync if there is phase lock between them : one frequency is multipley by number of two to other frequency, for that usually PLL circuit is used.
Again I ask ,if I have two signal generators and put one frequency to "50 hz coil" and other frequency to "380 khz coil" (right frequency for exact ferrite coil) do those two frequencies need PLL (phase lock) or to be synced?
Thank You!
T-1000
Quote from: grizli on November 03, 2011, 05:21:09 PM
Thank You!
Each generator has feedback with 1 turn on coil and keeps own frequency no matter what changes inside of coil. This is where you get synchronization.
The 50Hz is approx frequency because obviously we need standard frequency out of coil. You can tune +/- few Hertz and see where this frequency starts carrying frequency from coil of 51 turns.
FreeEnergyInfo
http://freeenergylt.narod2.ru/aidas/
TUNING INSTRUCTIONS ( DRAFT )
These instructions are for ferrite from TV tube ( cone geometry ) ОС-90.38ПЦ12 . Other types are not tested and may not work in your experiment.
You need to support resonance all time. No matter what input wave type is, the resonant output is SINUS WAVE
Each generator has feedback with 1 turn on coil and keeps own frequency no matter what changes inside of coil . This is where you get synchronization .
The main 50Hz frequency is because obviously we need standard frequency out of coil.
When using HV discharge for maximum output of ferrite cone , it most likely will heat up ferrite core and destroy it after 15-20 minutes.
If core heat up , lower HV discharge / generators voltage.
1. Connect  51 turns coil to Vector Network Analyzer output / Spectrum Analyzer intput
2. Connect  cooper plates half-ring winding to generator with white noise output.
3. Analyze and see where is largest peak on 1.2Mhz to 1.8 Mhz
4. Then connect  generator with square or  ramp at frequency of pick say 1.3 MHz to copper plates.
5. Tune it from 0 Hz to 1Mhz to maximum amplitude of 51 turns coil ( OSCILLOSCOPE AT OUTPUT ) .
6. Look for lowest harmonic resonant frequency of 51 turns coil with highest amplitude ( OSCILLOSCOPE AT OUTPUT ) .
7. Connect generator to 51 turns coil with frequency of readout .
ALL OF THE STEPS SHOULD BE DONE  WITH ONE GENERATOR ONLY!!!  AT THE TIME ...
8. Tune that generator to maximum voltage on bifilar output . ( OSCILLOSCOPE AT OUTPUT + hv probe and apply low voltage to generator output )
9. Connect second generator of 50Hz to 15 winds and tune it to maximum at bifilar . ( OSCILLOSCOPE AT OUTPUT )
   Tune  + / - few Hertz on it and see where this frequency starts carrying frequency from coil of 51 turns .
10.Connect flyback circuit with AV diodes plug and spark gap from our first experiment schematics to copper plates
    and tune variable capacitor attached to copper plates for maximum output .
11. See the response on oscilloscope  and / or light bulb at bifilar output.
12. Re-tune circuit  with two generators readjustment //
method # 2
instead of point 1.
and connect spectrum analyzer at  ( ekran ) shield  / coper strip winding
Note from Wesley :
if you have impedance meter  that  is capable  of choosing particular frequency and or display impedance at desired frequency ( 50 ohm between output of commercial generator ...
Then connected winding will be a load to the generator  in such way that after bifilar is connected with load than you measure impedance with
a- generator disconnected and impedance meter connected to 50 ohm than 15 ohm NO POWER!!!!!!!!!!!!! NO signal delivered!!!!!!!!!!! but light bulb connected!!
variable capacitor in series with the wire.. only one end of wire should be connected to say  ( 15winds ) ( in my case16 wind winding )
Wesley
For impedance match you will probably need unwind secondary coil or wind more wire on it .
The method determining that is : if you touch with one of secondary coil wires with finger or
additional wire which would be as antenna and see more bright halogen , you need more turns on secondary .
If halogen bulb (  220V / 150 W ) brightness fades , you need less turns on secondary coil .
