0 Members and 111 Guests are viewing this topic.
wattsup
@Hope
Thanks for the vote of confidence but like I said before, if I put time on that then I will put less time on the bench and that is time I do not really want to put elsewhere. There are guys here that can really do a good job on this so we have to be patient.
@stivep
Did not absorb all your post yet.
@T-1000
I have been experimenting today with a yoke that I have not yet taken apart just to use the original yoke coils and inner butterfly like coils. I have y two frequency generators pulsing the internal butterfly coils while connecting the yoke coils to a dioded capacitor.
While both frequencies were in a non-productive range I took a magnet and put it in the center of the yoke and can now here coil whizzing around the 5000kz and less ranges. When I took the magnet out, it inadvertently slipped from my hand and by chance got stuck to the yoke core right where the two halves come together and all of a sudden my LED bank lit up.
So maybe try to put a magnet where the two halves come together or between the two halves you can use two magnets, one on each side and see if you can notice anything of increase output. You can see in the image below the magnet is on the left side of the yoke.
wattsup
T-1000
Quote from: wattsup on November 03, 2011, 06:58:49 PM
@T-1000
wattsup
Usually magnet amplifies resonance effect and lowers inductance of coils and that leads to high frequencies and better effect. If you seen guys playing around with Joule thief and MEG, they have similar effect with magnet. Also my experience with it show amplified signal when secondary coil is between magnet and primary coil..
Still need to see if that can be useful when we're mixing 2 frequencies+ scalar magnetic field. :)
NickZ
    Wattsup:
   I don't know if you had seen this video, but for those who haven't, I thought that it would come in handy, at this time...
  The part where he is putting the magnet on the coil to raise the voltage to almost 500 volts from a single D cell is noteworthy, what would 12 volts do...
   http://www.youtube.com/watch?v=aiW6Vp08tfI
verpies
Dear Wesley,
@stivep
I can replicate everything in this device except the ferromagnetic core :/
Can you help us learn more about the core with which you have success by making some basic measurements, that will allow us to infer its BH magnetization curve?
Once we have this magnetization data then we will be able to select cores that are as close to yours as possible.
Jezeli nie ma Pan doswiadczenia w wykonywaniu pomiaru krzywych BH obwodu magnetycznego, to chetnie pomoge. Wystarczy zwykly oscyloskop, generator oraz kilka zwojow na rdzeniu. Byloby cudownie jezeli przebiegi z Pana oscyloskopu moznaby zapisac w postaci cyfrowej, poniewaz wtedy moglbym zrobic integracje numeryczna na zewnetrznym komputerze i wyprowadzic krzywa BH tego rdzenia
Pozdrowienia z Wroclawia,
Robert
stivep
Quote from: verpies on November 03, 2011, 08:01:24 PM
Dear Wesley,
@stivep
Robert
Bardzo przepraszam ale na dzisiaj juz mam dosyc :)... ide na urlop  :) zobacz tam  u gory masz kompletna instrukcje i  literature to mi wzielo  pare ladnych  godzin...dodatkowe informacje sa na
http://www.energeticforum.com/renewable-energy/9673-wesley-stivep1-video-high-voltage-frequency-ou-2.html#post165246 szukaj wypowiedzi T-1000 to jest Arunas z Angli
Nasza trojca to
Arunas Aidas i ja Wesley
Wesley
