0 Members and 192 Guests are viewing this topic.
stivep
Quote from Arunas:1.
Quote Connect  51 turns coil to Vector Network Analyzer output / Spectrum Analyzer intput
2. Connect  cooper plates half-ring winding to generator with white noise output.
The reason he decided to do it this way is because we have tried at my lab to use  sweeping generator from Vector Network Analyzer only at frequency range from  say 0 to 2 MHz ( we did not use VNA at that very moment to measure but only to sweep. (as if we have had  sweeping generator)
Instead of that you can use Sweep Generator  SG
The sweep generator is fast scanning generator and because  of FF analysis at Spectrum  analyzer you are able to see all of the spectral components and desired 1.3 to 1.5 Ghz.
The faster is the sweep generator the better is display of Spectrum analyzer.
but if you want to tune it manually  as long as you have manual sweep generator you are able also to see that effect.. only with much greater difficulty..
Note that generator must maintain steady  voltage at  given range of frequency swept.
such as  LEADER LFG-1300S
Wesley
wattsup
@all
I made a quick youtube with my new Samsung Galaxy SII Android Phone. Incredible little gadget. Man is it easy or what?
Regarding yoke and magnet.
http://www.youtube.com/watch?v=6j32phU5a6M
I have another youtube just uploaded regarding the 50hz and 380kHz that may interest ya'all.
http://www.youtube.com/user/wattsup1004?feature=mhee
What I forgot to mention in the second video is that the 50hz was set at 20% duty. At such low frequency, 50% duty is a total waste of energy, creator of excess heat and  actually was counterproductive to the energy process. The higher frequency was at 50%.
wattsup
T-1000
Quote from: wattsup on November 04, 2011, 01:35:57 AM
@all
wattsup
Cool,  see what happens when you put 2 frequencies into coils what have same winding angle in yoke (you probably will need to put another coil in) :)
Also, what is load power consumption and what is power of generators? Try to put more load than both generators can produce?
Please check for output voltage too, but be careful because it climbs to kilovolts easily when tuned into resonance. Also, the SINE WAVE must be on output coil from single generator no matter what type of input wave is.
Jimboot
Got my flyback. Just wondering if I should remove those chassis parts or will I need them for ground?
Mannix
Jim,
The metal bits hold the flyback together and there are 2 non metalic washers between the ferrites.
Depending on the tension on the nuts and the material between you can adjust the resonsnce .
Hook it up and see what happens the the resonsnce when you losen the bolts and move the cores ever so slightly apart.
I think it will become  a useful feature as we progress
