0 Members and 54 Guests are viewing this topic.
Jimboot
Quote from: Mannix on November 04, 2011, 06:23:58 AM
Jim,
The metal bits hold the flyback together and there are 2 non metalic washers between the ferrites.
Depending on the tension on the nuts and the material between you can adjust the resonsnce .
Hook it up and see what happens the the resonsnce when you losen the bolts and move the cores ever so slightly apart.
I think it will become  a useful feature as we progress
Doh thanks. Gathering my parts at this stage. Still unsure about the circuit but that was definitely a handy hint!
grizli
Quote from: T-1000 on November 03, 2011, 05:40:28 PM
Each generator has feedback with 1 turn on coil and keeps own frequency no matter what changes inside of coil. This is where you get synchronization.
The 50Hz is approx frequency because obviously we need standard frequency out of coil. You can tune +/- few Hertz and see where this frequency starts carrying frequency from coil of 51 turns.
Many of us DO not have stand alone signal generators
Any I plan to make stand alone circuit for driving , without stand alone signal gen
Why is feedback needed for keeping frequency? its quite opposite, feedback is usually needed when you tune frequency to something.
If you have signal generator and set one frequency it will stay the same for ever
I am still confused here ...
baroutologos
I think Grizly has a point here. How the one-turn (wind) feedback coil helps SG at remaining stable?
Another stupid perhaps question that is in my mind, is how the Signal Generators that output more or less 10 V can still function (provide current at particular frequency) when the resosant rise that the posted oscillograms show voltage climbs at primary coils more that 26Volts @ 380 Khz signal and 80Volts + at 50Hz SG?
Jdo300
I'll be getting in the game to replicate this device soon. I just picked up an old TV deflection yoke for free from a local TV repair shop (for those looking for cores).
Also, for those who need a cheap function generator, I have three of these that I've used for experiments in the past:
http://www.amazon.com/Elenco-Surface-Mount-Generator-Kit/dp/B0002LUAM0/ref=pd_sbs_e_3/191-9915946-8316205
They aren't top of the line but work well for anyone who wants to experiment on a budget. Also, since they run on 9V batteries, it is easy to monitor the input power.
- Jason O
