0 Members and 72 Guests are viewing this topic.
grizli
Quote from: T-1000 on November 04, 2011, 10:38:39 PM
It was used for TV display 61ЛКЗЦ - http://www.super-phantom.ru/arh/150/6/
Unfortunately, those are 25+ years old and no datasheets are widely available...
P.S> 61ЛКЗЦ = 61cm in diameter, 4:3 display with angle from cathode of 90 degrees. (other versions had 110^)
Have you tried to use ferrite core from newer TV ?
grizli
Quote from: T-1000 on November 05, 2011, 03:10:57 AM
Sure, and in our case there are half-ring copper plates on smaller part of yoke: http://freeenergylt.narod2.ru/aidas/pic2011-Oct-26_Wed_15-50-04_00006.jpg
The capacitor is connected to them and makes LC circuit matching ferrite resonant frequency which induce scalar wave impulses.
The secondary bifilar coil has capacitor and makes LC circuit which match to 50 turns coil frequency.
Time and experiments will show what is best.
Good luck for everyone who are building replications!
Whats the purpose of 50 hz coil than ?
What capacitor is connected to 50 hz coil and does it resonate with anything ?
Can device work WITHOUT 50 hz coil if HV spark gap and 380khz coil are used ?
grizli
Quote from: Jury1 on November 05, 2011, 04:43:33 AM
Hi all!
It seems that this time the miracle did not happen ...
I asked myself - why the lamp radiates light?
With increasing temperature, the Planck function tends to the Maxim.
Electromagnetic radiation is a very small part of the total radiation spiral lamp. This radiation provides an inert gas glow in the lamp. Efficiency of the lamp is very small.
If the lamp 100W shines brighter lamp of 60W
it says that I am not mistaken.
We have created conditions for the glow of gas in the lamp more efficient way ...
I have seen "cold glow", spiral of lamp was dark.
IMHO efficiency of the device is less than 1.
LOL
you cant make wire light bulb be 100 TIMES more efficinet.
Guys, have you measured current and voltage across light bulb ?
dynoc
Hy all,
I'm spokesmen of an italian "research" group,
until now we only follow the story to try to understand the system,
of course we're starting to replicate....sorry us for poor english.
Quote from: grizli on November 05, 2011, 05:19:59 AM
grizli, I think it's a carrying frequency...set to grid frequency, to have 220v AC on output.
-D-
verpies
Quote from: grizli on November 05, 2011, 05:10:15 AM
I actually DO NOT think so, because 380khz /50 hz is more than 7000 times... why would phase shift ration according to those two SO different frequencies have any effect ?
Because if the phase shift is zero then every peak of the LF waveform is lined up with the HF waveform peaks for all LF cycles. As you probably know, this leads to constructive superposition of the waveforms.
We don't know yet if this is good or bad, it's possible that destructive superposition is needed instead?
Also, 380000Hz / 50Hz = 7600
...even the quotient did not come out as a natural number, it can be made so because the authors allow the LF to deviate a little from 50Hz in order to "carry the frequency"
