0 Members and 73 Guests are viewing this topic.
Jury1
Quote… LOL
you cant make wire light bulb be 100 TIMES more efficinet.
Guys, have you measured current and voltage across light bulb ? …
IMHO the voltage and current in the lamp does not make sense to measure…
These measuring devices to work with electromagnetic induction ...
by electrostatic induction multimeters are crazy.
To continue a serious discussion, necessary to define - what is the "electric current"? What is its physical nature?
stivep
yesterday I have got link from Arunas
very important one
http://home.dmv.com/~tbastian/ball.htm
Our laboratory in Ohio (which is noted for slow wave helical antenna research) has developed equipment that will produce electric fireballs that will last after the external power is removed.
For those who is not familiar with firebals:
For close to 100 years nobody was able to create this effect.
lasting  factor is the delay what is needed to sustain motion before next impulse is fired out that is one of secrets leading to Tariel Kapanadze and/or most if  not all of Free Energy  devices self sustaining..
but this is not only one factor it is just one of factors
samozapitka means self looping  no external power delivered after initial impulse.
O boy we are close.........
it became apparent that the fireballs resulted form the interaction of two frequencies, a stray
                     higher frequency wave imposed on  the lower frequency oscillations of the main circuit....
This condition acts as a trigger which may cause the total energy of the powerful longer wave
                    to be discharged in a infinitesimally small interval of time and the proportionately tremendously
                    great rate of energy movement which cannot confine itself to the metal circuit and is released
                    into surrounding space with inconceivable violence.
Following Tesla's instructions, we rewired our apparatus as two synchronously pulsed high power RF oscillators, the first at a frequency of 67 KHz and the second at 156 KHz (The exact frequencies aren't critical).
The apparatus consists primarily of two one-quarter wavelength, slow wave helical resonators
o boy...
nie dawaj impulsu zatuchat!!! do not  let the impulse die I have still this words of Tariel Kapanadze in my memory .. he said it to me when we have had conversation in Tbilisi.
I want to see "oil barons" behavior when everything is over... I want to  see their faces... and the face of our former leader  Mr B..h
Wesley
Guys DOES IT  RING THE BELL FOR YOU? DO YOU SEE THE IMPORTANT CONNECTION TO  THAT WHAT WE WORKING  ON? JUST CONCENTRATE OF RED COLOR   FACTORS...
verpies
Quote from: Jury1 on November 05, 2011, 08:28:53 AM
Discussing the nature of electric current might be interesting but it is irrelevant to this thread, which is now focused on establishing the necessary parameters for the replication of this device.
In particular, the properties of:
- the ferrite core
- primary and secondary windings
- 1 turn Braid winding/HV electrodes
- waveforms (shape, frequency, phase, amplitude)
Once the device is replicated, we can concentrate more on the energy measuring methodology and the origins of the effects appearing in this device.
Robert
P.S.
If the device outputs energy in the form of electric current then simultaneous sampling of the instantaneous voltage and current of the waveforms at high frequency, followed by the time integration of their product is the correct way of measuring electric energy.  Calorimetry is also.
If the energy is not electric, then let's wait till the device works before we waste more time on such divagations and hypothetical measurements. ...but if it can do work and make heat, who cares...
gyulasun
Hi Jury,
Perhaps using a full wave bridge rectifier at the AC output, together with a puffer electrolytic capacitor (say 220uF/400V) to feed the lamps with a relatively pure DC voltage would help to get a much better measure of the real output power.
Fast diodes are to be used like BY399 (800V, 3A) or better to minimize rectifier losses, although the claimed output versus the needed input power can allow some losses here for sure.
Gyula
gyulasun
Quote from: Rafa12 on November 05, 2011, 08:02:03 AM
I am thinking in buy some Ferrite rings here, http://www.laboutiquedeliman.com/ferrita.html it seems they are not very expensive... But maybe the magnet form could be important? I think I will also try to get ferrite yoke to compare as there is an electronics recycling factory near my village.
Hi Rafa,
The link you refer to above shows ferrite magnets as far as I understand and permanent magnets are almost fully saturated, this means their permeability is very near to that of the air, i.e. 1.  So they would not serve as real ferrite cores for the coils at all.
You can surely find/obtain deflection yokes with their needed real ferrite core at the recycling factory or electric repair services at your local place, just visit them.
Gyula
