0 Members and 86 Guests are viewing this topic.
Rafa12
First pictures from an absolute begginer. Fortunately the yoke was divided...
Could I isolate the half yoke with inner tube?
T-1000
Quote from: verpies on November 05, 2011, 07:06:48 PM
I am purposely avoiding the analysis of the effects here, in order not to distract myself from the engineering variables.
I will delve into the theory of operation and all the effects once all of the engineering variables are known for replication
If that is holding you back and you are open minded.. Take TV yoke ferrite from TV what had 90 degrees deflection from cathode with similar geometry like there - http://freeenergylt.narod2.ru/aidas/pic2011-Oct-26_Wed_15-50-04_00000.jpg and just follow our work :)
http://freeenergylt.narod2.ru/aidas/aidas.bmp , http://freeenergylt.narod2.ru/aidas/Aidas_SHEMATIC.png and http://freeenergylt.narod2.ru/aidas/
Your engineering variables will disappear in tuning process.
Have fun!
verpies
Quote from: bolt on November 05, 2011, 05:55:54 PM
In the TPU the modulation frequency  is 5KHz. The carrier will be several Mhz.
It IS however vital to have modulation frequency of the NMR carrier.  Care should be taken not to over modulate but get as close to 100% AM  as possible.  Overmodulation will suppress the carrier. Under modulation will reduce level of magnetic flux field variation on the bifilar and thus directly effect the output power.
That makes sense. Here you are writing about AM modulation of the HF oscillator with the LF oscillator, where HF is the carrier. Obviously HF.f > LF.f
The language barrier makes it hard to extract this info sometimes.
For example take a look at the inventor's statement, and concentrate on the meaning of the word "carrying":
Quote from: T-1000 on November 03, 2011, 05:40:28 PM
The 50Hz is approx frequency because obviously we need standard frequency out of coil. You can tune +/- few Hertz and see where this frequency starts carrying frequency from coil of 51 turns.
To us, if it is stated that a frequency X is "carrying" a frequency Y, it means that X is a carrier frequency and the Y frequency modulates this carrier. Also most likely X > Y.
But to the foreign speakers it does not mean that at all!
In this case the author simply meant that the amplitude of Y is greater than the amplitude of X, as evidenced by his phrases "strongest signal" and "go inside".
Quote from: T-1000 on November 05, 2011, 05:20:31 PM
The lowest frequency has strongest signal so higher frequencies go inside of that signal, not otherwise
We have to be careful with the words when facing language barriers and we must ask a lot of questions or we will get confused despite the abundance of good will from the authors.
verpies
Quote from: T-1000 on November 05, 2011, 07:29:43 PM
If that is holding you back and you are open minded.. Take TV yoke ferrite from TV what had 90 degrees deflection from cathode with similar geometry like there <snip> and just follow our work :)
I will do that once that old Rubin TV set comes in.  I do not want to waste time on a different ferrite, because I expect the properties of this ferrite to be of paramount importance.
Meanwhile, I will bother you for the details in order to clear the info path for all the future replicators.
P.S.
If I hadn't an open mind, I would not be participating in this forum  ;)
I hope that you take no offense at my attempts to decipher your words. My remarks are not Ad Hominem.
Also, what languages do you speak? Maybe we have more than one language in common?
T-1000
Quote from: verpies on November 05, 2011, 07:41:07 PM
Lithuanian (native), Russian, English :)
