0 Members and 68 Guests are viewing this topic.
verpies
Quote from: aether22 on November 06, 2011, 07:28:25 PM
Question 6: So am I correct in summing the device as so:
A normal function generator is directly connected to a 50 turn coil and inputs a high frequency 50% duty cycle pulsed DC at over 300khz, nothing else is connected to this circuit.
You did not mention it is a rectangular waveform.  I am not sure if it is DC or AC.
There might be a 1turn feedback winding connected to the HF circuit. (50 turns).  There was a discussion about it several pages ago.
A second normal function generator (operating independently of the first) is directly connected to a 15 turn coil, this is set to about 50hz sine wave.
Yes, it is a sine wave, but we are not sure if it is a sinewave riding on a DC offset, or if it is perfectly symmetrical AC waveform.
There is a shield/braid/plate etc that can be made of various materials that was added so that it would work without needing body capacitance. <This is a guess
This is not electrically connected to anything unless you want to ramp up the power with the optional flyback option. (that will destroy the ferrite in time)
The Braid circuit is not optional. As a matter of fact I think it is the key circuit.
It must be connected and there must be current flowing through it, either from a HV transformer or from a parallel capacitor forming an LC resonator..
The braid/shield is in 2 pieces an inner and an outer, connected at one end to each other by a wire.
Yes, it can be in two pieces connected by a wire or in one piece (looped outside of the air gap).
The Braid is electrically insulated from the ferrite by plastic insulation tape.
The only point left to mention is that so far only one type of Russian made yoke has been used successfully and it has a 90 degree angle. (I hope this is not so and other different CRT yokes have proven successful!)
Yes. Precisely the Yoke ferrite is from a CRT that has a 90deg electron deflection angle.
It is very likely that this ferrite is a very special material, that e.g. changes magnetic permeability in response to the E-field of the HV Discharge. This effect has been observed by Konrad and Brudny in that IEEE article, that I had cited before, but only in few ferrite compositions.
T-1000
Will try to make some hints in single post for you guys:
However I have not yet found where to buy solid core wire with a plastic coating which is what I assume is used?
Should I still try anyway with either multi-strand or solid enamel coated wire?
It does not matter. Also if you make multi-strand insulated wire between strands, it will make stronger magnetic fields.
Question 2, what is the winding direction on the 2 primary coils? (unless it has been tried both ways and makes no difference)
And with the output coil, Do you wind the 2 wire together or in opposite directions like a caduceus coil? (that would explain why it doesn't feed-back into the primary and kill the gen.)
Clock wise, you can try different directions when you get first one running.
Question 3, So if I want about 150w output I don't have the braid connected to anything? And no flyback is used?
We used copper plates (sorry, but Wesley video made some confusion): http://freeenergylt.narod2.ru/aidas/pic2011-Oct-26_Wed_15-50-04_00006.jpg
One end is shorted by wire another end goes to variable capacitor tuned into ferro-resonant frequency. The scalar waves are induced on plates all the time.
Question 4, The braid does not pass between the core halves but a wire connects the inner and outer I assume? (or is the Braid in one piece?)
It does not. We have connection over bottom of TV deflection yoke.
Also see copper plates diameter on picture in previous question. My guess it should be not wider than 1/4 of deflection yoke heigh (not confirmed)
Question 5, I think there is much confusion and miscommunication about the 2 imputs along with plenty of unknowns so this question is perhaps the most important and is in 2 pieces:
5a: I have this function generator: http://www.amazon.com/Function-Generator-RSR-MHz-Sweep/dp/B0007ZGXCC/ref=pd_sbs_hi_3  and I will need to source another for the 50hz, for arguments sake let's say I buy another (just to keep it simple) would you expect that by directly connecting the output of each gen to their respective 50 and 15 turn coils I would be able to replicate the effect without any modification to the function generators or addition of any other circuitry?
5b: Please explain everything that has been used successfully to power the high and low frequency primaries, including any required (or awfully unseful) circuitry and the brand & model of the function gen. and details of the generated the waveforms. It looks like in the video 2 function generators are used, great if I wanted to buy them where would I go?
5a) Should do but you need 1-2 turns feedback coils for each generator for phase lock.
5b) http://www.vellemanusa.com/products/view/?country=us&lang=enu&id=523616
The 50 turns coil resonant frequency has sine wave out and square wave in.
The 15 turns coil has 50Hz(+/- few hertz after fine tuning) sine wave in. It is main transformer action frequency.
These coils are wound of solid 18AWG (or is it 18SWG?) solid core plastic coated wire. <I am most unsure about this point
The braid/shield is in 2 pieces an inner and outer connected at one end to each other by a wire.
The bifilar coil is wound together and connected so that the magnetic field generated by the 2 windings is in agreement as is the voltage induced, this is connected to a single halogen 150w bulb only. (although adding capacitors across the bulb may be desirable but not required, and capacitors can likely be added to all 3 coils)
And that the primary half of the Yoke is wrapped in electrical tape and there is paper separating the 2 halves.
The duty cycle was 39% in our experiment, 50% is way too much.
We tried different wires, no problem with them at all. The last time it was laminated copper wire :)
Will see if not Russian 90 degrees deflection yokes would work. The only 1 requirement for them is - they must have cone geometry for the sake of 1:1 replication.
Quote from: Mannix on November 06, 2011, 07:34:36 PM
I seem to have 1.6mhz and the 51 hz carrying 260khz like the picture but unless I pump  30 watts into the 50hz coil no light . It is very early and I was not able to tune the copper plate circuit  for any effect at this stage.
I see frequency multiplication and division using free resonant checking  that must be significant to be in faze somehow.
I wonder if we tune just with wire length ratios they might be more relative free resonant frequencies?
I am using another (slightly differnt)ferrite for version 1.00001
Did you manage to get http://freeenergylt.narod2.ru/aidas/2_pirmine_iskociojimas_pjuklas__50_hercu.jpg on secondary coil?
If yes, tyou are close. :) The input might be different but not something too much in regards of output.
The phase lock is achieved by feedback 1-2 turn coils into generators.
The copper plates make LC tank circuit, oscillating freely on ferroresonant frequency.
The secondary coil has LC tank circuit, the resonant frequency match resonant frequency of 50 turns coil.
We tried caduceus coil as secondary first then gone to bifilar. The bifilar coil gave less volts but more amps.
That's all at a moment, hopefully this will shed a light in the dark!
aether22
T-1000
1: Can you please show the shield circuit with capacitor and everything diagramatically? and or in a photo perhaps too?
2: I do not understand and I am clear that no one else understands how you are using the one turn coil for phase lock.
Can you PLEASE draw a circuit diagram of that with the function gen. and coil (1 and 50 turn) showing a whole circuit?
BTW my plans if I am ever in possession of a Free Energy device is to film myself building one from scratch with a parts list, explination/comentary and everything as clear as possibly from parts (or aquisition of parts) to tuning and running it.
Then upload that to youtube (in parts) or similar.
If even one successful FE inventor had done this we would all have FE by now.
Ok, one more thought. I don't know where to get a copper sleeve but I would hope that I could just make one with copper wires forming the same shape. But perhaps they would need to be well connected.
T-1000 do you think this would work?
Hope
Qwert
Hi.
I have an instructional pdf (35.7MB) to build a simple machine for EDM - Electrical Discharge Machining; the only tool to cut/remove very hard metals (conductive materials) by spark erosion. I can share it if somebody is interrested.
Edit.
Ferrite, according to Wikipedia is usually NONCONDUCTIVE material. The best way to cut it is diamond cutter together with plenty of coolant/lubricant mixture; a wet tile cutter sounds good.
