0 Members and 160 Guests are viewing this topic.
verpies
Quote from: Mannix on November 07, 2011, 02:59:35 AM
It would be good if  somebody could find an  easy way to test for its "propper function" before wrapping everything thing up  with wire and tape.
Did you try pinging the copper plates with a narrow sharp rectangular pulse?
They plates should "ring" even without a capacitor in parallel, after a rapidly falling edge of the stimulating pulse.
Ideally, the stimulating pulse should be of high voltage and with fast fall time.
The "ringing" should be sensed on a separate unloaded winding hooked up to an oscilloscope probe.
I would suppose that the short primary winding would do nicely for this purpose.
Expect this "ringing frequency to be in the MHz range and expect it to change after the secondary winding is loaded (loading allows a meaningful current to develop in the secondary and exert its effect on the resonance). Secondary does not have to exist for this test.
bugler
Can any one post the information to replicate the device.
This thread is so long that I have no idea where the essential information can be.
Thanks.
aether22
Quote from: bugler on November 07, 2011, 03:46:21 AM
Thanks.
At this point in time critical information regarding the function of an as yet unexplained one turn coil that acts as a feedback to perhaps keep frequencies phased locked somehow has not been given.
Therefore the apparently necessary info required to create this device is for some reason being kept making replication attempts an apparent waste of time.
Once this and info on the shield circuit is given replication attempts can begin in earnest.
Perhaps they are preferring to improve the device rather than share how it is currently done if that turns out to be less elegant than is possible.
T-1000
@T1000 Thanks yes I have the exact waveform in the picture.
What I dont have is any reaction at from the copper strips.
Ok, now attach diodes for HV before coil to save your generators from overvoltage then try HV discharge on peaks of sine wave? If that will lower input power needed from generators, you are on right way. The copper plates surely should be pumped with ferrite resonant frequency after this if your capacitor is tuned right on them.
P.S> It might tbe a case for more input power drawn if ferrite exciting frequency of 50 turns coil is on wrong ferrite resonance harmonics.
Collapsingfield
@T1000
Thanks for the new detailed info. I don't understand how can you give 50Hz to 15 turn winding by the mentioned generator. At 50Hz its impedance is much lower than 50 Ohm, the USB based generator will not able to supply it with power. Another question is that there is no input on the USB generator, where are connected the mentioned 1 turn feedbacks? Thank You for your efforts again.
