0 Members and 297 Guests are viewing this topic.
ramset
Thanks Grandma
dllabarre
Quote from: energia9 on November 07, 2011, 08:02:17 AM
i have experimented, things are happening the exact way aidas, arunas, wesley say, no theories will make your device work!  DO IT and you will know!!!
everything has to be adjusted piece by piece, you will not suceed with a fixed thing....
trust it, the phenomenon is not explained in conventional science, and media will still try to supress it although it can be reached by anyone this time.
All physics books needs either adding more info or completely rewriting... :o
WTG!....  best news I've heard all year (so far)!  ;D
I'm not too far behind you.
DonL
a.king21
Energia9,  Can you please post a photo of your replication?  Great news, by the way.
grizli
Quote from: Mannix on November 06, 2011, 07:34:36 PM
Serveral hours of bench time , unfortunately no bright light with my first build.
We do need a standard square wave oscillator with sync lock to use for hf primary.
Again WHAT  are you trysing to syncronise, what signal to what signal ? ???
grizli
Quote from: T-1000 on November 06, 2011, 08:57:09 PM
We used copper plates (sorry, but Wesley video made some confusion): http://freeenergylt.narod2.ru/aidas/pic2011-Oct-26_Wed_15-50-04_00006.jpg
One end is shorted by wire another end goes to variable capacitor tuned into ferro-resonant frequency. The scalar waves are induced on plates all the tim
WHAT IS CAPACITY RANGE if this varaible capacitor ?
Quote5a) Should do but you need 1-2 turns feedback coils for each generator for phase lock.
Phase lock to what ? what do we lock to what ? Do we want constant frequency or variable frequency that makes constant output voltage ? or constant phase lock, (if so what signal do we lock to what signals ) ?
If you used this signal generator http://www.vellemanusa.com/products/view/?country=us&lang=enu&id=523616
How does his sync function work ? Can anyone explain , hmm user manual says nothing about
QuoteThe secondary coil has LC tank circuit, the resonant frequency match resonant frequency of 50 turns coil.
Secondary coil ? you mean output coil=  load coil ?
For single turn 90 degree coil, can I use aluminum foil?
