0 Members and 70 Guests are viewing this topic.
escalator
Hi:
After reading again the last 20 pages of the thread I see that some people are asking how to sync the generators without any clear answer given. The Velleman generators used on the video have no sync input so I cant see a way to do it with those generators. All the screen captures shown are related to these generator models that work as standalone without sync capabilities. Someone can explain this?
wattsup
@all
I am planning to cut a copper strip about 1" wide and slip it into a shrink tubing and heat it up to have a nice tight fit to insulate it from direct core and wire contact, since this is the HV side and can quickly arch across open areas and result in premature breakdown. HV is serious business.
Also, and foremost I will wind the 50 turns with 1 center tap and the 150 turns coils with taps at 37, 75 and 112 turns to give it some more flexibility for future use. lol
@Mannix
I don't know but I have a funny feeling that if you are putting the 50Hz on the 15 turns, maybe try to put it on the 50 turns and the higher frequency on the 15 turns. This may be better for your yoke type/material. In my first tests with the standard yoke, this was best resulting output since I tried it both ways. I don't know why it is being done in reverse but given that the copper strip will receive HV and create a rather strong effect on the half yoke, trying to move the field at 50HZ may be difficult on the 15 turns since these are very few turns that are on the outermost layer of the primary coils and it will be hard for it to create a movement effect. Try the 50Hz on the 50 turns that is against the core. The 380hz (or whatever  higher frequency) signal on the 15 turns is enough because it will impress itself all over the core at such higher frequencies. But anyways, I will test it both ways when I am ready.
I have to say that if @otto was alive today he would have been so happy to see guys pulsing a yoke with multiple frequencies. This was the basis of his works for so long.
Oh, remember when we were at TPU123. Well I have saved most of the site before it went off line. The second image is a yoke coil I had built in June of 2008 following @ottos' bench tests. (NOTE: DO NOT REPLICATE THE YOKE COIL SHOWN BELOW - THIS IS JUST SHOWN FOR NOSTALGIA.)
@ALL AGAIN
If any of you have a good result, STOP, PLEASE do not change anything and document and post it ASAP.
wattsup
verpies
Quote from: grizli on November 07, 2011, 09:53:57 AM
I think you are wrong
maybe only exact way to see resonance on 90 degree coil is scoping that coil , while pulsing the same coil  ?
Pulsing copper sheet coil and scoping it after pulse goes away?
Its not the same if we pulse classic coil thats at 90 degree to copper shield coil
Yes, I can see now that my words have been ambiguous.
I meant exactly what you wrote: "Pulsing copper sheet coil and scoping it after pulse goes away"
Now, this "scoping" can be done in several ways:
1) Scoping the 1turn Transverse Coil ( the "copper shield" coil) directly.
2) Scoping the 15turn Primary Coil (classic coil at 90deg.) wound over the Transverse Coil
3) Scoping the 50turn Primary Coil (classic coil at 90deg.) wound over the Transverse Coil
In my last message to you, I meant pt.2 because it is safer for the scope when HV is used to ping the Transverse Coil.
P.S.
For pure measurements the primary coils should not be loaded with anything more than scope probes.
Ganzha
I have to say something about sync! I had asked about this matter several times but i have answer from nobody....BUT I asked from Tiger from Kayakstan (this shematics is originally invented by him) he aswered and I can clear this Q!
Look!
This is IMPORTANT!!!!
FQ 50 HZ ( it is vary betwen 48-52 Hz) is master! Fq of 382 Khz is slave FQ!
Dear Tiger! You great men who would save as from Oil monsters!!!!
God Bless You!
Ganzha
here is my ring not complete jet but.... tomorrow it would!
