0 Members and 364 Guests are viewing this topic.
Ganzha
Ok I will wait 3 days and then will publish schematic of Tigers anyway ;D
Maybe I should open a new topic because I believe that Tigers devices is not "successfull replicant of Tariel Kapanadze Device"!
Goat
Quote from: energia9 on November 07, 2011, 08:02:17 AM
i have experimented, things are happening the exact way aidas, arunas, wesley say, no theories will make your device work!  DO IT and you will know!!!
everything has to be adjusted piece by piece, you will not suceed with a fixed thing....
trust it, the phenomenon is not explained in conventional science, and media will still try to supress it although it can be reached by anyone this time.
All physics books needs either adding more info or completely rewriting... :o
@energia9  Congratulations!!!
It seems that you are the first one to replicate this experiment based on "things are happening the exact way aidas, arunas, wesley say"....
Could you post your procedures to get the same results so that people here on this thread could follow your footsteps as that would prove this experiment to be true...there's only one way to prove an experiment to be true is to duplicate it based on the information given...
So, if you could, please list all the schematics used,hardware, tuning, and any other information you can to guide other people to replicate your success.
Regards,
Paul
AbbaRue
About secondary coil:
If you listen to the video, at the end when he describes the 150 turns,
he states that he had 80 windings of each on his coil.
So this would tell me the 150 turns is total, or 75 windings of each.
I think 75 to 80 turns on secondary will just change output voltage.
I don't think this will effect the function of the rest of the unit.
AbbaRue
@cosmoLV:
Many people of this forum have spent years seeking for a free energy device that works,
and is easy to replicate.  They all deserve a working OU device after all this work.
Even if the powers that be stop this from becoming common, at least all of us on these forums will have
a working OU device of our own.  I believe governments will leave us alone, because it is better to keep
things quiet, then having a bunch of martyrs.  History has proved that martyrs speak very loud to world.
Now is there anyone that fully understands how to build this device? Including:
frequency generators
flyback circuit
braided wire
2 primaries
bifi secondary
tuning capacitor
wire AWG
output load
All these should be standard for all.
Questions that need to be answered by testing should be:
Frequency and amplitude of input signals
type of ferrite material
capacitor tuning
spark gap size
Hope
Quote from: Hope on November 07, 2011, 03:53:35 PM
Excellant news, please post all data you can to include photos, schematics, equipment used,  all P ins and P outs, waveforms at Pin/Pout's .  Do you have any precision 1 ohm resistors you can measure across?  Do you have any wattmeters or amp meters.  You can build a high voltage probe,  look at instructables.com for DIY instructions.  You can get a mega ohm resistor heavy enough from an old broken tv (the picture tube will work as a fantastic HV capacitor BE CAREFUL).  The bleed off resistor for the CRT (picture tube) at the ground straps area will work for a DIY HV probe, be SURE to incase it in materials that will protect you from getting ZAPPED!
Still awaiting my PCSU1000.
http://www.youtube.com/watch?v=aiW6Vp08tfI   wasn't Wattsup  was this YouTube
