0 Members and 1919 Guests are viewing this topic.
Pirate88179
    The author asserts that most closely to the solution approached Andrey [Melnichenko], but it will arrive yet not soon at his version of the solution. [Kapanadze] as motto repeats “you hold resonance!”. [Vobshchem]- that these are all information is carrying although some benefit. Rest it is necessary to extract from patent and video. But here also author himself:
Pirate88179
Here we will examine video. We will investigate separately patent.
What we do see on the film? They at first zealous bury radiator and they pour on by its water. Thus, they organized the grounding, shallow, not separately qualitative, but grounding. The area for the demonstration is organized after this, table will be carried, several instruments are established on it. From which it is possible to conclude the complete composition of demonstration installation To [kapanadze].
1. The first and key device is this the so-called “resonator”, green box with the sly device on the pylons.
2. How I understand this inverter, DC/AC converter to power on the order of 4 kW. Most probably amateurish performance. But not industrial (contemporary inverters they have another style of performance).
3. Rectifier. [Samopal] in the tin can, by which, apparently, charge [AKB], in the regular version of use.
4. [AKB] is automobile starter, ampere hours 60 by capacity, not new.
5. Load. Five lamps in the ceramic cartridges, the suppositional power of 1 kW. It is indirectly confirmed, to me sent the photo of precisely this lamp.
Here and entire composition of installation.
The following further occurs - they connect installation to the qualitative grounding (network of cold water supply), they include. Lamps light up, after which detach [AKB], and load continues to feed by device in the autonomous regime. The duration of start is not great, probably, inverter works in the maximum or beyond the limits regime. In the process of demonstration are produced the measurements of voltages and currents by the standard instruments, the frequency of work of which to 400 Hz this at best.
Pirate88179
The heap of the wires of those connecting installation and the quality of survey does not make it possible to examine component (what they wanted). As soon as the explicit admission of nourishment to the table it is not noticeable. It is possible to hope that this actually working device.
In the process of demonstration is made the switching from the qualitative grounding to the poor quality, after this output of device considerably it was lowered.
On the exterior of the device, besides sly coil on the pylons, there is another discharger:
According to the approximate estimation the space is calculated on 2-3 kV not more.
To the upper part of the housing are carried out the radiators, on which two keys are similar, radiators are cooled by the additional fan (apparently the regime of the work of transistors not affectionate).
But strictly
Pirate88179
But strictly But to strictly and add more thus far something, rest in the consideration of patent.
Pirate88179
JustasM, please feel free to correct any of my crude translations errors as I am sure there are many.  You know how these free programs are, ha ha.
I hope this makes sense to someone here.
