0 Members and 312 Guests are viewing this topic.
pix
Quote from: pix on November 09, 2011, 02:11:08 AM
All,
I am quite confident that you will not have a detailed plan and decent explanation why it works and what-to-do.
Otherwise you would have this already.
All the information we see on this forum regarding recent succesfull replication is provided in a very haotic and unprofessional manner.
Instead of clear explanation: "guys, this is how it works, the source of excess energ is ....., please see detailed schematic with pictures and do replication this way:... ect." - what we have?
Pieces and bits of info here and there,lot of videos, lot of "educate-youself-links".People claiming that they have an answer and working device -instead giving full explanation, engage in discussions with individuals.
Target is slowly "dissolving".
Information instead to be placed in one piece, is smeared through dozens of pages and replies.
I don't understand this.
Stivep, Zilano, T-1000
Please if you are willing to share, and you have a working  unit- try to condense and detail all necessary information in one document.
Not everyone on this forum have your level of expertise and such fancy testing equipment in large amounts.
People have limited resources to fail with their replications,just because information given is incomplete.For example,recently a lot of people was asking how do you phase lock two Vellemanns function generators.
How do you want to "improve the world and give energy indenpendency to the people" in a such messy and chaotic way?
Regards,
Pix
Hey people,As I said, no clear reply from "originators.
People strugglin to do succesfull replication because of incomplete information given..
I see now people everywhere looking for old TV sashing them into pieces for yoke.
This is ridiculus!
pix
aether22
Quote from: pix on November 10, 2011, 04:27:13 AM
This is ridiculus!
pix
It is, and yet they hold the cards.
They give us incomplete data so we can only run around wasting time and money trying everything or as I am and you are doing, moan about it.
The world doesn't have free energy, not because none have ever discovered it, but because those who do reliably keep secrets.
And on it goes, how much longer can the world hold out, waiting for someone to discover it that isn't playing games.
grizli
Quote from: verpies on November 09, 2011, 07:35:31 PM
Yes, it would seem impossible with the 15turn coil alone, because at 50Hz this coil has such a low impedance that it appears as a short circuit to the weak signal generator.
However, if the 382kHz frequency somehow changes the rules of the game, e.g. by significantly increasing the effective permeability of the ferrite through some exotic effect, then this changes the big picture.
In this expanded picture, the 15turn coil stops appearing as a low inductance and low impedance load (short circuit) for the signal generator, and the HF 382kHz oscillation starts riding on top of the LF 50Hz oscillation.
See:
http://www.jjgifford.com/expressions/geometry/wave_addition.html
http://freeenergylt.narod2.ru/aidas/2_pirmine_iskociojimas_pjuklas__50_hercu.jpg
So your observation about the apparently devastating short circuit at 50Hz, might turn out to be good news after all, as it shows us a contradiction that we can sink out teeth in.
The very existence of this contradiction/impossibility explains the inventor's emphasis on the tuning of the LF by +/- few Hertz, that always seemed enigmatic and unnecessary to me.
See the inventor's quote below:
The above instruction is unusual because in normally summed waveforms, the HF will ride on top of LF always without any difficulty and the success of this waveform addition is independent of their frequency ratio and phase difference.
BTW: Because of the language barrier, the inventors wrongly call the effect of Waveform Addition as "carrying", instead of "riding on top".
This wrongly suggests that the LF is some kind of a "carrier wave".
See:
http://en.wikipedia.org/wiki/Carrier_wave
The impossibility that you had just pointed out might provide a key to understanding the tuning of the whole contraption.
Also I cant see ferroresonance, it may be 5 Mhz.., but am not usre if thats shield resonance.
Because I get 5 mhz at shield only when I connect third harmonic of 5 mhz to 51 turn coil, at 25 turn coil it does not work (put many turns outputs for variations), when I use 75 turn coil I get nothing at shield, when I used 25 turn coil signal is little higher than 5 mhz
Also signal at shield contatin HF about 25 Mhz (and even higher and loweroscillations) and 5 Mhz..   HF part appears with just one wire to 51 turn coil, or even when core is physically near to drivin circuit
25Mhz oscllation VRMS is higher than 5 Mhz which looks like sine .
Connecting capacitor paralel to shield kills that 25 Mhz oscillations, and do not change 5 mhz frequency much
maybe tigers approach is BETTER, use sparg gap always, and you dont have to tune anything. It has all the spectrum and I will try spark gap to shield, and 50 hz...
grizli
Original inentors went away, and they dont even BOTHER to answer our questions  >:( :(
Thats sad  :(
bugler
Sorry to ask a silly question.
If the inventor was capable of producing 5kw of electricity why the guy in the video (some sort of friend of the invetor) shows only 60-100W output?
What is the highest output replicated so far ?
Thanks.
