0 Members and 1862 Guests are viewing this topic.
grizli
Quote from: baroutologos on November 10, 2011, 05:55:14 AM
:) I have mentioned before, a signal generator with a p-p some 10 or 20volts output, being connected at that 15turns coil to any type of ferrite, without any other addition or effect will give at best milivolts p-p scope shots at its ends.
The very effect that a coil like this in 50 Hz (agree with verpie) can have a voltage rise (simulating resonance) as Aidas shown around 130Volts p-p, demands a new physics book on its own.
I havent noticed such effect, and generatin such effect requires step by step instructions hmm
grizli
Quote from: verpies on November 10, 2011, 05:55:57 AM
s.
Anyway, all of the theorizing as to the origin of the effect is not the focus of this thread.
Let's replicate the device first without distracting ourselves with naming the possible internal effects and theorizing about "how it works".
We should concentrate on the practical tuning instructions and building it exactly as the inventors did.
After we replicate the device, we can theorize to our heart's content how it works.
TRied and failed,
Even spark gap I have used, with 50 hz with other wave types, etc, spark gap makes no increase in brightness at all ,..
Also, if we put some sginal to 15 turn  coil of lower frequency, that signal generates signal to 50 turn coil.. probably 50 turn coil require series capacitor to prevent signal generated from 15 turn coil be shortened by mosfet body diode of signal generator
FreeEnergyInfo
baroutologos
@ Grizly,
patience and we see
I was thinking that the team had a course so far. It firstly reported OU by having and running a flyback transformer by a custom inverter, collecting single wire via AV plug the HV to 6.8nf cap and discharging it via a spark gap to a primary winding. A parallel variable cap to the winding was also there for achieving many frequencies and tunning.
Power collection was on another winding no bifilar one as far i remember, again proceeding with a dioded cap, another spark gap and the load (lamp)
In that first instance, apart of the frequency sprectrum created by both spark gaps and the more specific frequencies attained by the variable capacitor, was there any shield perpedincular to windings? It has not been mentioned such thing.
see "sxema_rabociaja_darobotka" in the Lithouanian site. Although no explicit photos were given of that very first setup, i remember no shield to be mentioned, apart from the capacitative coupling between the primary and secondary winding due to HV created by the Flyback transformer. (hot lead to AV plug, cold one to output winding)
food for thought. Please any member of the TK replication team comment and give his view in terms of integrating all the observations so far.
verpies
@grizli
Good job.
This clearly is a negative result.  Negative results are very worthwhile, too. Scientific method requires falsifiability.
A low resistance, low inductance, 15turn coil driven by 50hz AC weak signal generator should develop negligible voltage across it according to conventional theory...and that's exactly what happens for you.
However, the inventors clearly demonstrate appreciable 50Hz amplitude in their video.
Unfortunately they do not show how the signal generators are connected and where the oscilloscope is hooked up.  It looks like they are measuring a LCR circuit with a high L/R constant (Tau)
The contrast is stark.
