0 Members and 154 Guests are viewing this topic.
verpies
Quote from: grizli on November 10, 2011, 03:07:41 PM
They reduced number of turns to just 21
Did you see it work with a decent load and those 21 bifilar turns ?
stivep
Quote from: grizli on November 10, 2011, 03:11:57 PM
Stivep, why adding cap to output coil ? after all resonance of output coil is much much lower.. about 220 kHz in my case, input 50 turn coil have about 1,7 Mhz in my case.
no open coil i not active resonance circuit.
Close one but tuned to 1.2-1.9Mhz gives scalar parameter even if spark gap is not connected.. Influence of this  circuit  works similar to  proximity sensor of regular store anti theft device
The only difference is  that it is active existence of circuit that by heaving its own EMF must back interact with  the rest of circuitry..
There is some of  difference  between approach of Arunas and me in regards to scalar  and/or NMR ir both mechanisms in the device.
That is what may confuse  you as it is  hard to us to  experiment in given  direction..
NMR requires set of steps  of different nature.
Wesley
bender
Quote from: stivep on November 10, 2011, 03:11:35 PM
That was for the purpose to find How it will behave if we reduce it to less than 150.
Second reason was the HV and safety to measuring   equipment.
Everything is as fresh to you as it is to us.
Plenty of hours just to find more...
Talking about  4 guys  for several hour..  and some of them has to go to work or avoid working day...
some of others have to go to bed at 6 in the morning...
Wesley
Wesley, thank you and your team for the hard work...we are all waiting on new instructions and hoping we will all have working unit on our tables soon :)
verpies
@stivep
Would you work with me to improve the text on http://freeenergylt.narod2.ru/aidas/ ?
There are many English errors there, both spelling and grammatical as well as semantic.
I am well qualified linguistically and scientifically to improve this text.
stivep
Quote from: verpies on November 10, 2011, 03:16:27 PM
At 21  winds the voltage is much much smaller.
I suggest to concentrate at process not at number of winds.
Do not let yourself get confused
keep original concept. 150 winds
Mechanism of tuning is important
You  can deliver lower voltage  from generators to do not blow out your oscilloscope or SA..
Or use  1:1000 probe.
We also do not want to  get it damaged...
Wesley
