0 Members and 107 Guests are viewing this topic.
Ganzha
Quote from: stivep on November 10, 2011, 05:37:27 PM
[/glow]
[/b]
The only difference between me and Arunas is  whether the phenomenon of OU is of scalar or NMR  nature.
At the end it is important that it works.. not how it  works to many of you.
But approach is different when  NMR is investigated as responsible one for  the effect of OU.
Everything takes time.
You have been waiting for OU  many years..
First successful video based on  TK was published month ago..
Second successful video with Yoke  ferrite was published  few days ago..
If you think that we know a lot you might be disappointed
Most of what  we knew is what you know  thanks to effort of the  group
Aidas
Arunas
Wesley NY
If it was  as easy as  some of you might of expect we would be perfecting OU  20 years ago when transistors and diodes become  very powerful.
Wesley
Ок! But maybe You (Wesly) could send e-mail a JP Kelly about this matter - this is device of Tiger anyway - with TV yoki especially!!!!!
And please say to people that yoki device of Tiger is not a Kapanadze device! Stop your  washbrein!
I do respect you but, please stop!
wattsup
@ALL
I just got today another flyback that I think has no diodes. The numbers on the flyback are as follows.
TCE 26.5 kV
2825004-502
RXE
CTC 167
I will try to find a pdf or other info on this flyback first. Otherwise I will identify the coils by hand.
I now have my Yoke all made up and have done some start tests. This yoke is much smaller then the one I used for @ottos' works.
Pulsing a Yoke Coil 3
http://www.youtube.com/watch?v=_Pk5khbykmU
Pulsing a Yoke Coil 4
http://www.youtube.com/watch?v=LfCpoSyoOUU
Pulsing a Yoke Coil 5
http://www.youtube.com/watch?v=_rFc7Z_zaOU
Pulsing a Yoke Coil 6
http://www.youtube.com/watch?v=FR5YDawEBu8
Some frequencies are identified but these are preliminary and do not regard the second frequency which I will do next. This is where the fun starts. lol
One main thing is about the copper strip. I found no effect on the secondary when sweeping through the frequencies. Only one small effect at 10.6MHz and some little jumps here and there. So basically there is a very wide open window of no effect between the copper strip and the secondary core which leads me to think that the effect of the HV on the copper strip is mainly confined to the Drive Core. Since it is wound one turn horizontal, the waves are going up and down unlike the vertical primaries 1 and 2 where the wave is going left and right. Seems like the up and down in the Drive core cannot reach the other core because of the gap. So the HV produces a horizontal wave and the primaries flip it to vertical where the secondary core can see it. At least this is a simplified explanation of possible effect. So this is good. One way to test this theory is to take a virgin yoke, put a copper strip on one half like we already have and put any numbers of turns coil on the other half but this time also wound horizontally, then pulse check with cores placed one on top of the other. If the secondary produces more output at a wider frequency range, this would confirm the effect which would be very interesting and an authentic direction for further research.
Here is the system information for the  Pulsing a Yoke Coil videos.
Load Group
1 diode 1N8330
1 capacitor 10uF 370v
1 LED bank of 18 red leds that starts lighting at 5vdc.
1 Fluke 73 multimeter.
1 Hitachi V-650F 60MHz Oscilloscope
Drive Group
HP1 - HP 8116A Pulse/Function Generator 50MHz
Settings: Square Wave, frequency variable, 50% pulse width, 16 vpp,  HIL 8vdc LOL -8vdc
Direct Drive Group to Load Group Results (Video -Pulsing a Yoke Coil 3)
Highest Best frequency was 4.00MHz gave 9.94 vdc off the dioded cap.
I have added another 0.5 vdc as a margin so as a benchmark, if through some pulsing method the
multi-meter reads higher then 10.50 vdc with the same load, then there is something special going on
and this warrants further investigation. Adding a second FG in parallel to the first directly on the Load Group added 1 volt to the test but let's add another 0.5 volts, so as it stands, with two FGs if the voltage reading rises above 12 vdc, I know something is special. This also provides an easy method for identifying the coupling efficiency of the methods.
Drive Half Yoke Core
Three elements, a one turn copper strip, a 50 turn Primary 1 and a 15 turn Primary 2.
CS (copper strip - 1T) 0.5 ohm at 0.00 mH
P1 (yellow-50T): 0.5 ohm at 0.96 mH
P2 (green-15T): 0.5 ohm at 0.11 mH
Generator Half Yoke Core
Two winds of 75 turns each in bifilar (total 150 turns) provides B1 and B2.
Three taps at 25, 37 and 50 turns, not used in this experimenting.
B1 (violet): 1.0 ohm at 0.68 mH
B2 (white): 1.0 ohm at 0.68 mH
B1 + B2 bifilar (white to violet): 1.2 ohms at 2.72 mH
B1 + B2 parallel (white to white and violet to violet): 1.0 ohm at 0.69 mH
More when it is done.
wattsup
Acca
Here is a link to the Aidas Web page, most of this in English. THIS IS A MUST READ TO ALL THE NEW PEOPLE..
http://freeenergylt.narod2.ru/aidas/
Here is also a link to the Russian Aidas video .... that is on a Russian server, it is an .avi video file, it is two hours and it is in Russian language. You need to down load this file to play it !! it's 271 megs...
http://narod.ru/disk/31105359001/AIDAS%20VIDEO%20%202011.11.09.avi.html
Some one will have to translate this...
For people who understand the impossible...Al..
Dla ludzi, którzy rozumiejÄ..., co niemożliwe ... Al ..
Jdo300
Hello Everyone,
Looks like this thread has been going other directions for the past few pages so I thought I would post my practical build progress so far. Attached are a few photos I took while assembling my unit. I created a copper strip and designed it to fit the taper of my cone (mine, like Philm's, doesn't have a significant cylindrical form at the bottom). I also wound both my primaries onto the first half and will be preparing to wind the secondaries tomorrow.
Though after looking at some of the original pictures, I'm reconsidering to rewind the primaries with smaller wire since my 50-turn coil needed two layers of winds to fit on my core. I'm not sure if this is a problem or not but I may reconsider rewinding if it is necessary for the 50-turn primary to be wound as a single-layer on the core (Wesley & T-1000, could you please give me your feedback on this?)
Thank you!
Jason O
Acca
