0 Members and 91 Guests are viewing this topic.
Ganzha
Stivep (wesley) stop foolish people! It is Tiger device with Yoki of USSR TV set that he build since 22 Jan 2011/ You and others from your band in that time dosnt even dreams about this device! There is pics from video from Russian forums where Tiger (Kazakstan) did show his device.
A have attached a schematics of this device which Tiger send me yesterday. People - use this instead of othres not relieble "replicators of Tiger devices". I should repead ones more - this is NOT REPLICANT OF TARIEL KAPANADZE!!!!!
Name of this Devices - Reactor #2 from Tiger 22_01_2011/
God Bless Tiger!
PS I can easyly prove that device with Tv yoki is  Tigers device and his name is not Aidal from Lithuania! I am able to prove that he first time published video and schematic since 22 Jan 2011/ Easy speaks - Tiger is inventor of this device!
T-1000
Quote from: Ganzha on November 12, 2011, 08:50:26 AM
Stivep (wesley) stop foolish people! It is Tiger device with Yoki of USSR TV set that he build since 22 Jan 2011/ You and other from your band in that tive dont even dreams about this device!
If you look closer, he used single blocking generator with HV discharge in combination and our device use 2 generators for input plus HV discharge in full configuration.
Again, seems you are deaf to the fact that Tiger is the part of our team .. ;)
verpies
Below please find the translation of Russian phrases on Tiger's schematic diagram (in the order of left->right and then top->bottom):
"LF waveform without HF should be a clean sine wave"
"All on one core. The HF winding back-to-back on opposite ends of the core."
"Short on negative half-wave"
"HF 10-20 times higher than LF"
"дросселъ" = Choke
"искра" = Spark
@T-1000
Why do you keep ignoring my simple questions?
Msg. 8680: "Where was the primary winding of this transformer connected ?"
Ganzha
Quote from: T-1000 on November 12, 2011, 08:57:35 AM
I have written proves that your @band@ that called itselv as a "team" did  try to avoid this fact that Tiger is in yout "Team" in internet!
verpies
@ALL
I think I see another diffence between Aidas/Arunas/Wesley's (AAW) configuration and Tiger's.
Namely, Tiger's configuration seems to use the bilfilar coil connected in bucking mode (back-to-back serial opposing) and AAW's configuration seems to use the bilfilar coil connected in serial reinforcing mode.
The Russian phrase on Tiger's diagram
"All on one core. The HF winding back-to-back on opposite ends of the core.""
and the dots denoting the directions of the bifilar windings on the schematic, seem to imply the above.
