0 Members and 103 Guests are viewing this topic.
T-1000
Quote from: itsu on November 13, 2011, 10:49:10 AM
@ all,
New measurements, observations and preliminary conclusions on my replication attempt:
http://www.youtube.com/watch?v=tr1pslkZBrE
Starting to rebuild: new copper strips, new 50 turns coil and new output coil (both with a natural resonance frequency at 50 Khz)........
Regards Itsu
In the pic where 382 khz in and sine wave out, multiply by 8 - it contains 8 waves inside between 2 measurement points.
The 50 Hz to 15 turns coil is directly from 9V 0.75a mains transformer output.
itsu
QuoteIn the pic where 382 khz in and sine wave out, multiply by 8 - it contains 8 waves inside between 2 measurement points.
Thanks T,
so what you are saying is that the 47.85 Khz sine wave signal seen in the screen shot is really only 1/8th of the whole 382Khz (sine wave) signal, meaning that we do have a 50 turns resonance frequency of 382 Khz?
Ok about the 50 Hz from the 9 v transformer, i tried that too (without the bulb), but it was as a short to the transformer and ran hot.
will try it again now i have rebuild my copper strips and 15 turn coil which has higher inductance.....
Regards Itsu
T-1000
Quote from: itsu on November 13, 2011, 11:28:30 AM
Did you ran another generator on 50 turns coil on the same time too?
itsu
QuoteDid you ran another generator on 50 turns coil on the same time too?
Yes,  i did, but things went better with the bulb included (not running so hot).
Then i found that my base 50 Hz wave together with the 382 Khz wave riding it did not match your screenshot.
The separate 382 Khz wave was not visible at all, just a "thickening" of the 50 Hz wave outline.
Could be my DSO though, presenting the signals different then yours.
Regards Itsu
