0 Members and 37 Guests are viewing this topic.
jbignes5
I keep hearing that someone else invented this.
Well it was Tesla who invented this and here it is: http://www.teslauniverse.com/nikola-tesla-patents-390,721-dynamo-electric-machine
The problem I see with the current design is it is only half of the system Tesla designed. In Tesla's design it was a rotating machine that made it's own oscillation Through the exciter portion of the device. There are two inputs one on and the other off. These inputs vary back and forth continuing the motion in the same direction around the ring. The first bank of coils on the ring are the generator coils. The exciter field coils around the rotor generator coils present a field for the rotor generator to convert down into very high current. It is a transformer in all effects. When you try to stop the rotor from turning it will generate extra current from that effort. The lines cuts the rotor coils further generating more current in the process. So one could say this is a steady state Device. When you try to stop the rotor you get all kinds of current and that can be used for a motor to help keep the rotor in sync.
The one thing That I have not seen much is the mixing of longitudinal waves that the copper strip is emitting, inside and outside of your device. This is like a surface of water. Then the coils disturbs the surface pulling in more energy into the system through resonance or an inward direction. My thinking is that the north wave is following around the yoke and the south wave is also following around the yoke to. The bifilar is picking up both waves in respect to the north and south and using both to add to one direction based on the split of the coil. This creates a bigger bang for the buck or a fulcrum like effect.
What they have done here is only half of the drive. Check out the parallels to Tesla's work.
verpies
T-1000
Quote from: jbignes5 on November 14, 2011, 09:39:05 AM
We reinvented the wheel :) Like all other inventors around the world. The all credits go to Nicola Tesla!
And of course, the genuine approach of mixing longitudinal waves with common magnetic waves is half work. The second half is nuclear polarization in ferrite core... :)
grizli
T-1000
Quote from: grizli on November 14, 2011, 10:20:33 AM
what determines frequency of low frequency coil ? (above transistor)
The main resonant frequency from copper plates. You take resonant harmonics with highest amplitude from it and use for 50 turns coil tuning.
