0 Members and 385 Guests are viewing this topic.
orel1
Quote from: verpies on November 15, 2011, 08:46:39 AM
If you are still in Slovenia then you should be able to find one of the following Russian TV sets that were imported from Russia during the cold war.  These TV sets have that magic ferrite OC-90.38ПЦ12 in them:
Foton C-220.
Wjesna C-276
Gorizont C-256, C-256(D), C-257, C-257(D).
Rubin C-201, C-205, C-207, C-255(D).
Elektron 722, 723, 724, 725 726, 72S, 731, 733, 734, 736, 738, 739, 740, 741, 742.
The names and symbols above have been transliterated from the Cyrillic to Latin alphabet.
I'll check that, but I doubt I could get som of these, as there were several companys in ex Yugoslavia that were manufacturing TV sets.
Thanks a lot.
wattsup
@All
It may have cost me a meter but I did find this out.
Putting 16 vdc on the copper strip is one thing but when the copper strip gets HV from the flyback at the frequencies I was trying from 1Hz to 50MHz, nothing on the 15 turns so far.
At high voltage, we can start throwing out all our previous results. This is serious stuff. The flyback filled my cap so fast and then beyond, when my LED bank was not on. But when the LED bank was connected, the HV toasted it and my multi-meter. MY MISTAKE. I was only pulsing the flyback primary with one of my FGs and did not expect so much output. Man do these flybacks fly or what?
HV on that copper strip means the whole coil half will be resonating and for the life of me, I don't know how @T-1000 managed to hold the yoke in his hands and split the halves while the device was running with HV. The rule would be better as "ONCE ON, KEEP CLEAR", because of all those wires all over the place you never know when your hands can touch on of them live ones. OUCH. Man does it hurt or what.
I think ultimately, all these resonance procedures will not work because they are being done out of HV context. Every volt you add or subtract from the pulse will change the resonance points. Every duty width will also change this. So I think the best and really only way to find the frequencies will be when all the right voltages are applied to the pulses and you start playing around with the three frequencies at the same time.
So think of the HV as the one that applies a spring to the core atoms holding them in one position and the two primary pulses as the forces that make the atoms turn in one direction or another. Each time the atom turns and is released, under natural forces it would take time for the atom to revert back to its natural directionality, but with the HV over the cores, this is not happening naturally but the atom is forced back into a bias position so each pulse of the primaries is exerting a maximum swing to the core atoms. It is this maximum swing that is conveyed to the generator coil core that is then seeing this a being supplied by a huge coil when in reality it is being fooled to see this and respond with more output.
Here are a few useful flyback links;
http://purco.qc.ca/ftp/Inventors/Tariel-Kapanadze/wesley/flyback-transformer/Flyback_Testing.pdf
They talk about a copper strip in the flyback in this one.
http://purco.qc.ca/ftp/Inventors/Tariel-Kapanadze/wesley/flyback-transformer/Inductor.pdf
Stancor Transformer Catalog
F:\aaaa-overunity\tariel kapanadze\wesley\flyback-transformer\stancor-catalog
More testing.
wattsup
PS; I can only place one attachment to the posts so I  have just pointed to where they are on my OU FTP site.
T-1000
We used 2 Nicola Tesla methods and nuclear spin polarization  for achieving our results.
Method of exciting environment with resonant frequencies: http://www.rexresearch.com/teslamos/tmosc.htm
"I was experimenting with vibrations. I had one of my machines going and I wanted to see if I could get it in tune with the vibration of the building. I put it up notch after notch. There was a peculiar cracking sound.
"I asked my assistants where did the sound come from. They did not know. I put the machine up a few more notches. There was a louder cracking sound. I knew I was approaching the vibration of the steel building. I pushed the machine a little higher.
"Suddenly all the heavy machinery in the place was flying around. I grabbed a hammer and broke the machine. The building would have been down about our ears in another few minutes. Outside in the street there was pandemonium. The police and ambulances arrived. I told my assistants to say nothing. We told the police it must have been an earthquake. That's all they ever knew about it."
Method for creating artificial ball lightning: http://home.dmv.com/~tbastian/ball.htm
"...it became apparent that the fireballs resulted form the interaction of two frequencies, a stray higher frequency wave imposed on  the lower frequency oscillations of the main circuit....
This condition acts as a trigger which may cause the total energy of the powerful longer wave to be discharged in a infinitesimally small interval of time and the proportionately tremendously great rate of energy movement which cannot confine itself to the metal circuit and is released into surrounding space with inconceivable violence.
It is but a step, from the learning how a high frequency current can explosively discharge a lower frequency current, to using the principle to design a system in which these explosions can be produced by intent."
Effect of nuclear spin polarization: http://www.ursi.org/Proceedings/ProcGA02/papers/p1907.pdf
"The polarization of electron spins cannot be
stored for a long time since it rapidly vanishes after the controlling signal is switched off.
The nuclear spin qubits, on the contrary, possess sufficiently long relaxation times T1, up
to several hours at low temperatures [2]. Hence, nuclear spins can be considered as the
best suitable candidates for a qubit [3].
  Moreover, even in the absence of the external magnetic field, the hypefine can
produce Zeeman splitting of the conduction electron spins, equivalent to that of an
external field of several tesla. This is an example of a ''potential'' magnetic field caused by
the nuclear spin polarization.  "
Qwert
Guys, don't you think that Otto's findings can be accomplished somehow to this (your) experiment? This one for example:
http://purco.qc.ca/ftp/Overunity.com%20-%20Forum%20members/otto/ottos-open-tpu/
Even if not, I find it a pleasure reading this kind of story. I hope you'll like it, anyway. For those who don't know who is/was Otto: I consider him as another hero of this forum (after Tesla), he was present here till last year, when he died suddenly.  His posts can be found all over this forum; great experimenter…
Post Scriptum:
After hitting "Reply" button to reply, I culdn't find the "Post" button, so I am forced to use the other option to post. (I guess, it's another error of yet another improvement at this Forum).
forest
 ;D
There is also one possibility ..... look... very interesting
http://www.youtube.com/watch?v=LxTrT50mJMQ&feature=related
Noise level...
Fake a "working" Ou device and let people to invent it for youself  ::) very clever physological method
