0 Members and 54 Guests are viewing this topic.
verpies
The forum's code and  database is acting up again.
Posting does not work very well
verpies
Quote from: T-1000 on November 16, 2011, 05:19:54 AM
The optimal was half height of yoke. With full height we still need to finish testing, it is not confirmed result.
Obviously FCG PCGU1000 has no protection on output and we accidentally burned it again. Now it needs to get repaired.
Did you power your device with:
1) One signal generator and a low power (9V 250mA) mains transformer,
2) Two signal generators (PCGU1000),
3) Something else altogether.
What was the power dissipation of the load when you tried the "optimal half height" copper strip ?
P.S.
Did you consider building a well protected buffer/amplifier for the output of your valuable PCGU1000 ?
itsu
@ all,
thanks for the reactions.
Mannix,
good to have similar results, the cro/analyser is a DSO (Digital Storage Oscilloscope) from Owon, type PDS8202T (200Mhz).
Baroutologos,
I will do your test in the next days, i have limited time today/tonight.
T-1000,
thanks for the "skype" support offer, will keep it in mind, perhaps time differences are in play here and could give a problem.
Verpies,
The 2 potentiometers used were 100K and 5K (used in the video), but gave similar (none) results.
I will try to regulate the amplitudes of the both 15 and 50 turns coil, and redo the FG sweep test with sine wave.
Yes, seen the latest update, i keep that in mind for next experiments, however, wider thick copper strips pose a
problem on how to attach them flatly on the Y-shape yoke, perhaps copper tape/foil could do.
regards Itsu
T-1000
Quote from: verpies on November 16, 2011, 05:45:42 AM
50 turns - PCGU1000
15 turns -  low power (9V 250mA) mains transformer
Did not measure.
P.S.
We did, Aidas tried to find most common circuit for AC signal. One of things we would like to use is here - http://freeenergylt.narod2.ru/aidas/sustiprinimo_kaskadas.jpg
stivep
http://www.youtube.com/watch?v=8xnq62SSg84
New video English Version( translation)
It is not professional translation but  at list  is clear enough
We volunteering   To make this material accessible to you guys  in English but it is work of few days just to edit that material. mostly done during the night time,
when I'm busy with  videos than :Arunas is in the that time handling by himself  all of the
- forums at that time
-mail
-subscriptions of new approachers
-experimenting
-chat,skype group chats
And we are trying to have little life for our self too. :)
3 days translation and cutting.( including  download of video from Arunas and problems with huge file)
2 hours   conversion
2 hours download
2 hours pocessing by youtube
Anyhow I'm better and better with that  videos translation is not easay for me as I'm not native rusian nor I ever have been to Russia.
Wesley
