0 Members and 160 Guests are viewing this topic.
T-1000
Quote from: semenihin-77 on November 17, 2011, 07:18:18 AM
It is interesting videos posted DELAMORTO
http://www.youtube.com/watch?v=M9fPQfRUMDU
This effect shows what happens when you mix 2 frequencies together and use earth connection as counter-mass to accelerated particles in spin. The first time it was seen by Nicola Tesla when he was making artificial ball lightning.. ;)
Also coils are on 90 degrees, what make reference to our experiment.
grizli
Quote from: leo48 on November 17, 2011, 06:41:33 AM
This is translate from russian to english with GT
Thangs
Leo48
Hmm, where is load ? what dies coil do ?
baroutologos
Quote from: baroutologos on November 17, 2011, 04:47:21 AM
Part 2
Initial question remains. How those FG manage from burning out? They start with a signal of 10v at their leads, and voltage can climb as much as 1Kv.
Hey T-1000.
Is it much trouble for you to explain me this small detail? Thanks
T-1000
The impedance and frequencies have answer to that. Same as using few turns coil in step-up transformer and driving circuit for it.
P.S> We are not dedicated 24/7 to this forum so be patient for getting answers.. :)
jbignes5
I understand now what the difference is in the two metals. Copper sucks this stuff in and condenses it by heating up. The heating up is proof that there is a conversion going on. The aluminum only transfers this energy and no conversion or little is done with the pulse. Thats why Tesla was so in love with Aluminum. Think of the aluminum strip as a sonar device and you will see what you are doing. You are polarizing a slice of space then vibrating that surface. As the surface vibrates it also twists to either side of the polar surface. This twist is made by the 90 degree out of angle copper winding. The field is a heavy magnetic field when compared to the pure voltage potential field the Aluminum emits and it twists the high voltage polar section into a cone like protrusion.
The only difference I can see by your method is that you don't really have a way to extract the motion of that vortex field. This is why Tesla used higher voltages in the field coils of his device and let induction do it's job in the rotor coils of converting the high voltage field into higher current fields in the rotor winding. It was easier to do it that way because the bucking fields stopped because of the higher voltages.
You might think of it like this. Using aluminum in the field coils to emit a high voltage field, this field can be moved very very easily. The copper of the internal winding of the rotor suck up this field and change into heavy current which can be used for any load even itself through capacitance connection.
The magnifying transformer is probably the key to this venture. Thats what Tesla made that for.
