0 Members and 55 Guests are viewing this topic.
energia9
Quote from: Shokac on November 17, 2011, 10:30:03 AM
;D
Congratulations my friend Wesley but, after spent lot of money, I think it is not looking in the right direction.
You spent too much money but not enough time to experiment.
verpies
Quote from: baroutologos on November 17, 2011, 04:47:21 AM
As its shown wire composition play a major role for a reason i cannot understand. (go figure)
Solid wire has more Skin Effect than stranded wire.
Skin Effect favors lower frequencies.
leo48
QuoteHmm, where is load ? what dies coil do ?
I have translated the text of dynatron to understand how it works
thanks
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
verpies
Quote from: T-1000 on November 17, 2011, 07:30:29 AM
Also coils are on 90 degrees,
Only perpendicular coils can produce a rotating magnetic field. (2 or more coils/windings are needed to do it)
In free space, rotating magnetic field acts like a fan that propels electric charges via Lorentz force q(vxB) where the v comes from the relative motion of the rotating field (not the absolute motion of charged particle).
Who knows what it does in ferri/ferromagnetic materials ?
jbignes5
You are starting to get the idea now. Tesla figured out that to either side of this surface is polarized fields. His bifilar winding takes advantage of both polarities and orients them in the same direction. You could think of this like this: through the fans equator is a plane of electric field. The coils around the outside are what creates the fan blades so to speak. They still need counter rotating coils to increase the effect of the twisting fields for collection. They are trying to only collect the momentum of the fields instead of collecting them in coils especially made for that, they are missing half the extraction and almost all of the potential of the fields. Collection should be on both sides of the ferric ring using bifilar winding so that each field can be extracted from each side of the surface they created with the HV pulses then swirled via the copper winding. When this is done they will see the true power that these fields contain.
