0 Members and 55 Guests are viewing this topic.
verpies
Quote from: baroutologos on November 17, 2011, 09:33:53 AM
What about the 50 hz frequency? In the end, it is the 50 hz volatge frequency that climbs up to KV range (without any load attached). Impedances at those 50 hz are not worthy to be mentioned at constraining currents at those 50turns primary or 15turns from inrushing the signal generators.
Yeees.
This is a highly unconventional behavior.
Conventionally, the high impedance of the 15t coil @ 50Hz could be explained with a very high effective inductance, most likely caused by very high permeability of the core.
...but we know that the core has very low permeability (see Osiakosia measurements) and Itsu's experiments show how the low frequency waveform from the signal generator collapses when shorted by such low inductance (low impedance) winding.
The only non-sociological explanation is that the other perpendicular windings do something to the the core material to increase its effective permeability dramatically.
semenihin-77
semenihin-77
Quote from: jbignes5 on November 17, 2011, 12:36:24 PM
You are starting to get the idea now. Tesla figured out that to either side of this surface is polarized fields. His bifilar winding takes advantage of both polarities and orients them in the same direction. You could think of this like this: through the fans equator is a plane of electric field. The coils around the outside are what creates the fan blades so to speak. They still need counter rotating coils to increase the effect of the twisting fields for collection. They are trying to only collect the momentum of the fields instead of collecting them in coils especially made for that, they are missing half the extraction and almost all of the potential of the fields. Collection should be on both sides of the ferric ring using bifilar winding so that each field can be extracted from each side of the surface they created with the HV pulses then swirled via the copper winding. When this is done they will see the true power that these fields contain.
Very correct idea!
Waves
Very [color=rgb(0, 0, 255) !important]correct[/color] idea! Right direction!
