0 Members and 147 Guests are viewing this topic.
wojwrobel
hello
I'm not electrician ,but not many of them don't know how exactly stuff works, what i know is that "static" potential difference occurs with high voltage so there have to be high voltage involve to get "free" electrons from ground (just like in video)
Reinjenering Kapanadze video shows exactly this, there is high voltage because of the sparks that we see, and that red thing is a step down transformer that changes high voltage low amperage to low voltage high amperage
in school they learned me this P= V x A
P power
V voltage
A amperage
so no mater if you have let say 10000V at 0.01A
                 or                          100V at 1A
you always have 100W of power
and that red transformer does exactly this it changes high voltage low amprage to low voltage high amperage
its all about idea that is showed in video that i have posted in priviest post
so its all about CHARGING BY INDUCTION
cheers from poland
wojsciech
xenomorphlabs
It is NOT what is shown in the video, when you CONSIDER the admittedly somewhat "cryptic" comment the replicator has issued yesterday.
QuoteOne of our results is at ~ 40 volts input and consumption power ~ 200 mA 2 * 300 watts lamps.
40 Volts * 0.2 A= 8 Watt INPUT
600 Watt OUTPUT
8 Watt != 600 Watt (2 * 300 Watts for the lamps) !
The whole point of Kapanadze´s device is to have a multiple
times higher output (that can do work) than input, which they don`t teach you in school.
The replicator has made no further explanation how he measured
the "2 * 300 watts lamps", which sounds like strangely powerful lamps.
And maybe that was not what the replicator wanted to actually indicate, so the 300 watts per lamp are supposed to be their rating only.
In that case i don´t understand why he did not state what he actually measured, but that is the data he provided.
We will have to wait for his announced "better" videos to see what he really gets out.
forest
Tesla once said that if you understand method of  liquefying air you will understand how to produce more electricity from less.The same process.Like pump !
Electricity must escape under pressure and the work done by decompression is used to further compress electricity.
In other words :
1 take small amps at high volts ,release
2 take envinronment electron current created by escaping electricity and put back adding to step 1
3 repeat until current reach required power (voltsXambient amps)
4 convert PART of process into normal current (low volts huge amps)
Simplicity.KISS
xenomorphlabs
Quote from: forest on February 16, 2010, 12:39:46 PM
In other words :
Simplicity.KISS
Wow !
You figured it out!
Everybody is looking forward to your schematic or first build  ;)
Nevermind the sarcasm, but the forum is 90% full with theories like that, but the practical realisations are lacking "a bit".
But that replication and the guy`s intent to share it is a big hope.
wojwrobel
hello
i went thru patent and what i think hes using this 40V at 0.8A to positively energize the primery "coil" so second "coil" is trying to keep up so when connected to ground it "sucks" electrons from ground then when its balances (1 coil protons = 2 coil electrons) he disconnects the groung and then disconects 1 "coil" so he has charged 2 coil with electron to use
thats what i think hes doing
as i said in previest post its all in charging by induction andstatics ,it needs further investigation
wojsciech
