0 Members and 249 Guests are viewing this topic.
verpies
Quote from: baroutologos on November 18, 2011, 09:05:49 AM
3) u name it..
Yes, that's exactly what is needed.
STAAAR's definition of "clear" might be a little different that ours, though.
as pt.3 I would like to add simultaneous sampling of the voltage and current in the windings by a DSO, and publishing these waveforms in numerical forms.
verpies
Quote from: xenomorphlabs on November 18, 2011, 09:08:19 AM
I have a hard time imagining unidirectional transformation, so i still assume the HV signal gets transformed
into the other winding.
Why?
Voltage buildup is a conventional phenomenon for LC circuits that store energy.
Not so for purely resistively loaded transformers, though.
Consider a leaky transformer with just two windings of 1:1 turn ratio.
The secondary is shorted by a capacitor, forming an LC oscillator.  In an ideal inductor and capacitor with no resistance, the energy will be sloshing back-and-forth between them forever.
More energy can be slowly added to this oscillator by a loosely coupled primary winding driven at the 1/(LC)^0.5 frequency.
After some time a lot of energy can be accumulated this way in the secondary LC circuit (leading to high voltage amplitudes)
The current in the secondary will not induce the same current in the primary because the transformer is leaky and the primary lacks the mechanism for storing reflected oscillations.
This is conventional behavior.
T-1000
The latest test was done on copper plates without capacitor, the generator is attached to them. Other coils was not used for this effect.
As you already know, the configuration we got makes standing wave.
Here is link how they look visualy in water: http://vimeo.com/14153775
The same principle is observed everythere no matter what people may think... ;)
verpies
Quote from: T-1000 on November 18, 2011, 10:01:24 AM
Other coils were not used ?
So where was the HV ~25MHz 100W output measured?  On copper plates, too?
T-1000
Quote from: verpies on November 18, 2011, 10:09:27 AM
The measurement for power was done on 50 turns coil + antenna in SWR.
P.S> We're on the another military crysis because of the oil(most likely) again :(
http://news.yandex.ru/yandsearch?cl4url=www.profinews.com.ua%2Fget.php%2F21505%2Frossiya-ugrozhaet-byivshim-stranam-varshavskogo-dogovora-yadernoj-vojnoj
http://www.prisonplanet.com/russian-warships-enter-syrian-waters-to-prevent-nato-attack.html
So alternative sources of energy have to come in no-time...
