0 Members and 420 Guests are viewing this topic.
Ganzha
Quote from: verpies on November 19, 2011, 07:45:20 PM
The driving circuit for the HV TV flyback transformer is very much in-topic of this thread right now.
If you are willing to change your approach a little and forsake using your signal generator+amplifier to drive the primary winding of the flyback transformer, then you may try this simple efficient high power proven circuit.
If you use a variable capacitor for C1 then you can vary the oscillation frequency continuously, just like with a signal generator.
I have published schematics of Tigers device - all what "group of Wesly": says is quite  different because they are like you - they are "in progress of trying to replicate" device of other creator!
PS  http://germaschka2011.narod2.ru/
semenihin-77
That is the principle of the coil Tariel:
ball-passing pulse with a flat coil
Feeder-ball "primary" coil in the video "Aquarium", she is a high-frequency magnetic field - the transmitted pulse accelerator
In a coil through which a pulse will be induced current
No ferrites in the coil can not be Tariel, a brake pulse!
http://i081.radikal.ru/1111/82/53ef422cc7b7.jpg
forest
Quote from: semenihin-77 on November 20, 2011, 03:36:56 AM
;D ;D ;D inertia up and inertia down  :o but first we must learn how to produce this inertia wave  :P
T-1000
Quote from: T-1000 on November 18, 2011, 07:29:52 AM
Also for this effect you need to de-gauss ferrite (like in old TVs). Without it looses capability over time.
So we found what is happening. The ferrite core becomes magnet. You need compass to see it. :)
We're working now on constand degauss while preserving all effects.
P.S> The Russian deflection yoke is pure glittering black color. Most other ferrites have more gray color.
verpies
Quote from: bolt on November 19, 2011, 08:21:54 PM
Basically anyone who has bought or is using a standard sig gen MUST use some kind of an amplifier like this to pump at least 10 watts into the coils.     The blurb from the website about this topology says: "  The main difference of the half-bridge converter...
...and for non-rectangular waveforms this must be a high-power linear analog amplifier.
The simple Half-Brifge two transistor circuit does not work as a linear analog amplifier !!!
It is a double Class B amplifier that's good only for rectangular waveforms.
For non-rectangular waveforms a Class-A or Class-AB amplifier is needed.  Linearizing the H-Bridge is such a chore that it's better and cheaper to buy a premade amplifier.
There are many Video Output Amplifier or Line Driver integrated circuits that perform this function well from DC to 100s of MHz at power levels up to 25W.
The STK392 video deflection amplifier that the STAAAR team has been looking into at maxes out at 1MHz.
There are faster and more powerful Video Output Amplifiers and Line Driver ICs out there, ready to be used (made by e.g.: Sony, Phillips, MSK, AnalogDevices, etc...)
