0 Members and 322 Guests are viewing this topic.
Mannix
you can degauss anything with a decaying alternating magnetic field .
A transformer with the i cores cut out (open end)
A drill with a spinning magnet (poles out)
A magnet on a string spinning (poles out)
The important thing is the decaying field  is slow
no need for a big blue ring (unless the yoke has unusual  domains as well)
Try all of this on a colour tv CRT  and you will get the hang of degaussing methods ..its fun at least
verpies
Quote from: T-1000 on November 21, 2011, 05:56:35 PM
Manual Deflection Yoke Degauss - http://www.youtube.com/watch?v=jfgAwRnyWsY
The ring inside of blue isolation tape is coil powered by mains of 50Hz 220V.
Does it help?
How long before it needs to be degaussed again?
baroutologos
@ Verpie,
Regardin the wave riding case, i have seen again this. That is a lower frequency wave being the "ground" (or point of reference), whereas a higher frequency one oscillating at its crests like a "surfer wave".
The below image was taken a couple of years before by user RomeroUk, in his efforts to replicate Kapandze device.
They have an analogy of 1:10 and LF is about (do not remeber excactly) 300 Khz.
verpies
@Baroutologos
If the LF was fed by a high impednace source into a low impedance winding @ 300Hz and the LF voltage amplitude across the winding did not follow the I*Z relation, then indeed this was some unconventional ratcheting effect.
@All
For those who do not know what a ratchet is, see:
YouTube Ratchet
Hope
Quote from: Ganzha on November 19, 2011, 11:50:17 PM
I have published schematics of Tigers device - all what "group of Wesly": says is quite  different because they are like you - they are "in progress of trying to replicate" device of other creator!
PS  http://germaschka2011.narod2.ru/
In your orginal message you have a schematic with two transistors, one is PNP and one NPN BUT both are marked KT819 as the type????   Thank you.
