0 Members and 359 Guests are viewing this topic.
Hope
 :(    Can anyone tell me why ALL my downloads from this site have a .part extention???  I am not able to download anything for the past 4 days?????   WHAT'S UP????
Also concerning the spark gaps,  according to Tesla's findings : placing the spark gaps between a magnetic field (magnets) amplified GREATLY the ouput!!
Would ANYONE please comment if this post is found??
jbignes5
Quote from: Hope on November 22, 2011, 07:44:30 AM
:(    Can anyone tell me why ALL my downloads from this site have a .part extention???  I am not able to download anything for the past 4 days? ??? ?   WHAT'S UP? ???
Well you can liken it to a gun going off. It was a major portion of his amplifying transmitter! Haven't you heard that analogue is much better then digital in this case. In Tesla's mind he could create infinite oscillations that way, used that to his benefit. Keep reading about the spark gap and capacitance discharges and it's capabilities. He did extensive research into that area and I believe it is the root of all his discoveries. Such simple technology that held so much power.
After all when substituting Fluid dynamics all the parts make sense. Capacitor (reactive pressurized container), Spark Gap (pressure release, frequency Controller) and in my opinion shaped pressure inlets and outlets (short-able field Emitter\Collector coils(Rotor)).
I am thinking He learned a lot about the field and how it behaves inside of iron as well. It was said in one of the books about him that he gave Westing House a new type of iron that was more efficient then what they were using for transformers of the day. This iron was very soft and I can't remember the name of it off hand. I will en-devour to find it again and give the details.
All Iron acts like a channel to this energy. It contains the field, well mostly. It can be pressurized so the field spills out but still follows the circular shape. You can make waves to the field inside of the pressurized doughnut. The peaks come out of the shape momentarily and follow their own rules of inductive fields. These peeks are extreme potential with great powers of induction and can generate huge inductive fields for the briefest of time.
Resonance of the matter of the iron only increases this result. I assume this is what you guys are seeing here when you resonate the ferric core. This must allow the fields to break the surface of the iron by syncing to the field and it doesn't see the difference electrically between the iron and field. This allows the field to expose itself beyond the iron or ferric core and inducing into the wires wrapped around the core.
stivep
some of notes.
Deflection yoke. ferrite.
for those who want to play with this concept do not purchase generator that has maximum frequency of 2 mhz
After the while  main resonance frequency of ferrite changes.
One major problem that we have experienced is that when we sweep and/or delivered withe noise to U shape
and say 15 winds  was used to connect spectrum analyzer than pick resonance  expected to be  from 1.2 to 1.9 MHz with time  jumped up to 2.2MHz. That would not be a problem but my generator -Wavetek was damaged because of Chinese cheap voltage conversion transformer that show on its label 220 in and 110V out  but in reality was 220 to 220V
The  generators originally used  max 2MHz.
So  recommended generators are  less than 10 MHz max.
This part of test than was limited to measurement and working regimes investigation.
Demagnetization of  ferrite ring from deflection yoke  did help ,but with the time jumped again to 2.2 MHz.
Remember that second step would be to deliver 2.2MHz to U shape from generator and find  maximum pick on 10 winds again that one will be in within the range of kHz say 380KHz..
Because each ferrite is different that  these parameters are different as well.
Does not make  any difference if primarily you have connected withe noise to U shape winding but reading was done on 15 or 50 winds. result  of  reading  will  be the same  in regards of frequency 1.2-1.9 Mhz.
Repeating effect is not easy  even for us.
Group of 4 people  plus additional two at some moments was working approximately 20 hours a day for period  from Saturday till Wednesday  on two  concepts.
First working concept.
Conformed as  what it looks like  100% success.
That is the concept from video
http://www.youtube.com/watch?v=nJBpNKSsdqw
Wesley
Legal note:
We are  not responsible for any experiments that you make for yourself.
We do not recommend or encourage anyone to make this type of experiments
High voltage is very dangerous and may cause serious consequences.
If there is any other danger that we do not know about it is solely your decision and your responsibility.
Simplify that statement.
Do not do it and do not play  with it ever.
All of our comments are  directed for promoting general knowledge .
Words used "you make it" or "you connect " and/or  similar in  nature  are directed to licensed electricians who at their own responsibility and/or decision decides to experiment with it.
verpies
@itsu
Could you post purchasing info for that cheap Chinese signal generator of yours?
I think I heard you say that it can go up to 5MHz and I saw that the output driver parameters you measured, were pretty decent.
I think Wesley could use several of these signal generators...
Quote from: stivep on November 22, 2011, 08:54:42 AM
...my generator - Wavetek was damaged...
itsu
Quote@itsu
@ verpies,
it was already mentioned (and turned down because of the shipping costs :-) ) by e2matrix in his post #8719 on page 582.
It goes to 5 Mhz, yes.
Be aware it has a full range (110V - 240V) ps, but comes with US type mains plug, see picture on the add.
Concerning the air gap i am using, its still there, and is normal thickness 80 gram printer paper.
The 15 and 50 turns are 1.5mm od (15 awg) solid copper wire, the 150 Turn bifilar is 18 awg stranded wire (loudspeaker wire).
I received 2 large variable capacitors (35 - 345 pf) for better tuning, however it introduces 2 more tuning parameters :-(
Regards Itsu
