0 Members and 133 Guests are viewing this topic.
LtBolo
Not intending to come across as skeptical...but...has anybody seen any of Utkin's devices demonstrated or replicated successfully? There are so many pictures of coils, somebody (presumably Utkin) has spent considerable time building. And yet with all of those coils, is there a single video anywhere demonstrating the devices? If not, I would be very cautious about jumping ship and building those devices. I can give you five explanations of free energy, and all might sound plausible, and all might be wrong.
One functional device is worth more than 100 books full of theories and pictures.
On the other hand, if he has successfully demonstrated free energy devices, then it is a very interesting document indeed, and his discussion about Mislavskij's transformer may have specific relevance to the ferrite yoke core device.
grizli
Quote from: verpies on November 21, 2011, 11:12:15 AM
@itsu,
Nicely made video.
The problem of the 274kHZ not riding on the crests of the 50Hz is exactly what Grizli and Baroutologos had been griping at.
See their quotes below:
I have mentioned before, a signal generator with a p-p some 10 or 20volts output, being connected at that 15turns coil to any type of ferrite, without any other addition or effect will give at best milivolts p-p scope shots at its ends.
The very effect that a coil like this in 50 Hz (agree with verpies) can have a voltage rise (simulating resonance) as Aidas shown around 130Volts p-p, demands a new physics book on its own.
Indeed the above should not happen according to conventional physics even if we account for the resonant rise phenomenon.
Also, note that the Russians wrongly write "LF carries HF" instead of "HF rides on LF".
This is a grievous mistake in English language because the former expression is reserved for AM modulation that involves multiplication of two frequencies (the carrier and a signal) and the latter expression denotes waveform addition (which is what is visible on STAAAR's oscillograms).
I would venture that the HF will not start riding on top of the LF untill you enable the 1t Transverse Winding, either by:
1) energizing it from an external source, or
2) adding a parallel capacitance to it, or
3) increasing the surface areas of the copper strips (which accomplishes the same result as pt.2)
...as a side note, in order to maximize the capacitance in pt.3, the distance between the surfaces should be minimized. This means thin plastic tape layer and flexible strips that will "hug" the core closely....
Going out on a limb even further I speculate that the 1t Transverse Winding should resonate on one of the harmonics of the 50t Winding and be 90deg. out of phase to it, because that arrangement will certainly create a rotating magnetic field and possibly spin the magnetic domains in the ferrite. I hypothesize that spinning magnetic domains will increase the effective permeability of the ferrite and this will cause increase of the inductance of the 15t winding and the resulting increase of impedance at ~50Hz.
More impedance means less current in the 15t winding circuit (e.g. light bulbs get dimmer).
PRACTICAL ISSUES:
Please remind us what kind of air gaps (paper gaps) you have now and whether you are using stranded or solid wire  (with skin effect).
Changing to a lower resistance bulb (or adding more of them in parallel) in series with the 50Hz transformer and 15t winding, would not hurt performance as long as the transformer does not overheat.
If you ever see that light bulb/bulbs getting dim, then you you'll know that you are getting closer
Hm,, if that all would resonate, than we have to expect MYSTEROUS EVENT, and that 50 hz signal FEELS very high impedance ? :o
grizli
Quote from: stivep on November 22, 2011, 08:54:42 AM
some of notes.
Deflection yoke. ferrite.
for those who want to play with this concept do not purchase generator that has maximum frequency of 2 mhz
After the while  main resonance frequency of ferrite changes.
One major problem that we have experienced is that when we sweep and/or delivered withe noise to U shape
and say 15 winds  was used to connect spectrum analyzer than pick resonance  expected to be  from 1.2 to 1.9 MHz with time  jumped up to 2.2MHz. That would not be a problem but my generator -Wavetek was damaged because of Chinese cheap voltage conversion transformer that show on its label 220 in and 110V out  but in reality was 220 to 220V
The  generators originally used  max 2MHz.
So  recommended generators are  less than 10 MHz max.
This part of test than was limited to measurement and working regimes investigation.
Demagnetization of  ferrite ring from deflection yoke  did help ,but with the time jumped again to 2.2 MHz.
Remember that second step would be to deliver 2.2MHz to U shape from generator and find  maximum pick on 10 winds again that one will be in within the range of kHz say 380KHz..
Because each ferrite is different that  these parameters are different as well.
Does not make  any difference if primarily you have connected withe noise to U shape winding but reading was done on 15 or 50 winds. result  of  reading  will  be the same  in regards of frequency 1.2-1.9 Mhz.
Repeating effect is not easy  even for us.
Group of 4 people  plus additional two at some moments was working approximately 20 hours a day for period  from Saturday till Wednesday  on two  concepts.
I kind of  think that even You and your team CANT replicate OU device any more ?!
why not making video that contains that also ,,.. the same video ,same core = setting resonance + working OU device with light bulb, the same one that was tunes using PC scopes..
hmm
verpies
Quote from: wattsup on November 22, 2011, 02:38:45 PM
I went to my local EE shop and they did not have the IRFP220N that is in your circuit diagram. Also, they checked and there is no replacement listed. So I am wondering if what I already have on hand may be OK and if so, do I have to change the resistor and cap values.
The Power MOSFET should have a drain-source voltage max rating that is 4 times higher than the power supply voltage.
For 2x6turns primary the maximum drain current should be above 30A.
For example: the IRFP260N has the maximum source-drain voltage of 200V and max drain current of 50A, so with this MOSFET you could power your circuit with up to 50V power supply and a high power flyback.
The toroidal choke L1 is there to protect the power supply from current surges.
The Zener diodes are there only to protect the gate of the MOSFETs.
For example: The gate of IRFP260N can withstand up to 20V so an 18V Zener diode should protect it adequately.
The capacitor C1 and the number of primary turns determine the oscillation frequency, as follows
f = 1 / (  2Ï€ * √(LC)) , where
f  is the frequency in Hertz
L is the inductance of the primary in Henries
C is the capacitance of the capacitor in Farads (electrolytic capacitors will not work here)
The choice of the diodes and transistors does not influence the above oscillation frequency much.
The choice of transistors affects mostly the power level.
The flyback core should have an air gap, or it will not work with this circuit. Flybacks have this air gap by design. It is usually covered by the HV secondary winding.
jbignes5
Quote from: grizli on November 22, 2011, 05:39:33 PM
I don't think anything should be 50hz when playing with these fields. Tesla warned that low cycles of this stuff from mono pulse to anything up to 2k cycles. At 2k they become more subtle of a pull. Things that have lower densities react less to this field it simply doesn't affect it much. but the average of the mass of this Aether which moves readily because they are smaller and react better to the stimulation of higher harmonics. Resonance isn't hard to see if you look for it in this process.
