0 Members and 87 Guests are viewing this topic.
verpies
Quote from: T-1000 on November 22, 2011, 03:54:13 PM
Not bad, it is full usage of coils placed in 90 degrees to each other. That needs further exploration because it creates pendulum analog from mechanics :)
No, two perpendicular coils create magnetic rotation, not pendulum-like back-and-forth magnetic oscillation.
See the animation of two orthogonal coil pairs below (click on it to see it rotate):
John M
Quote from: LtBolo on November 22, 2011, 04:56:46 PM
Not intending to come across as skeptical...but...has anybody seen any of Utkin's devices demonstrated or replicated successfully? There are so many pictures of coils, somebody (presumably Utkin) has spent considerable time building. And yet with all of those coils, is there a single video anywhere demonstrating the devices? If not, I would be very cautious about jumping ship and building those devices. I can give you five explanations of free energy, and all might sound plausible, and all might be wrong.
One functional device is worth more than 100 books full of theories and pictures.
On the other hand, if he has successfully demonstrated free energy devices, then it is a very interesting document indeed, and his discussion about Mislavskij's transformer may have specific relevance to the ferrite yoke core device.
I don't think anyone should jump ship either. Who knows, this could be miss information. It does however go into simple experiments to help verify the theory. It does make sense. I always believed that Kapanadze defeated Lenz Law to help get the effect he sees.
Using the yoke leaves me to believe that ferroresonance might be involved which negates Lenz Law also. It seems that once Lenz is defeated applying high voltage opens the door for electrons to flow in.
I personnaly will be experimenting with the ideas in this document. I think Kapanadze is the real thing and this document might come very close to explaining it.
John
verpies
Also when this is used with core resonance, it make even more effects.
In the STAAAR device the magnetic H-field is 2-dimensional because it is created by perpendicular windings.
Your drawing below does not show that.
...but it does show correctly that the E-field created between the surfaces of the capacitor is perpendicular to one of the the H-Fields.
Actually the E-Field is perpendicular to both of the H-Fields but the drawing does not show that either.
This creates a 3-dimensional mutually perpendicular field vector arrangement (two H_vectors + one E_vector).
Of course if you are not paying attention to the phase difference of the two perpendicular H-fields then you might create the 2D rotating H-field by chance only.
T-1000
Quote from: verpies on November 22, 2011, 07:36:30 PM
Not by chance, but intentionally :)
The solution to that problem is..  the Caduceus coil when you put plates with 1/4 length of 1 coil turn on 2 coil places in coil ends where wires are intersecting in caduceus coil!
Explanation in Russian:
http://www.youtube.com/watch?v=hDXEC6GeGA0
stivep
This is the link to new video one of series of videos  from experiments provided bu group of people for humanity  and by humanity.
I intend to get  with all of the material to you.  5 people are  capable of delivery of the same material.
If I will have any problems you will be notified by members of the group and asked for  your help, protest, action or more.
You  also will be told why I decided to  prepare you in case of problems.
Additional supporting material
than will be presented as a support  of the case.
Wesley.
