0 Members and 90 Guests are viewing this topic.
T-1000
Magluvin
Quote from: jbignes5 on November 22, 2011, 06:29:42 PM
I don't think anything should be 50hz when playing with these fields. Tesla warned that low cycles of this stuff from mono pulse to anything up to 2k cycles. At 2k they become more subtle of a pull. Things that have lower densities react less to this field it simply doesn't affect it much. but the average of the mass of this Aether which moves readily because they are smaller and react better to the stimulation of higher harmonics. Resonance isn't hard to see if you look for it in this process.
Are we talking about any event that happens under 2khz?
Sine wave through a coil? Square? Pulse? Unidirectional pulse? 2kw amplifier into a wall of 10 inch woofers at 35hz? 50kw amp(s) wall-o-subs, 60hz pulse, 170db?
Or are we only talking about using quenched spark effect?  Are you guys quenching? hmm?  ;]
We live in a sea of 50hz/60hz. Both within the range you specify. How long do we have?  ;]
From what I read, not from TU yet, is that the effect(s), only happened when the source "high tension" is discharged into a stout conductor, in a unidirectional fashion, via quenched spark, or, like Edison, connect a 4kv running generator to the mains.
I remember Otto, he had experienced some of these things. Jimboot posted not feeling well from running his version of the Ossie motor.
Also, from what I understand here, is that the 50hz injection is not really anything like what Otto or Jim was doing. Unless the spark discharge is at 50hz, of which, im not familiar.
Mags
I think cell phones are 1 thing common thats way under regulated. over 2khz.
John M
Quote from: T-1000 on November 22, 2011, 07:50:50 PM
Not by chance, but intentionally :)
The solution to that problem is..  the Caduceus coil when you put plates with 1/4 length of 1 coil turn on 2 coil places in coil ends where wires are intersecting in caduceus coil!
Explanation in Russian:
http://www.youtube.com/watch?v=hDXEC6GeGA0
Did you notice that they edited the schematic that is in the document I posted earlier. This is a very good video, I wish someone could translate it.
John
TEKTRON
Quote from: Hope on November 22, 2011, 07:44:30 AM
:(    Can anyone tell me why ALL my downloads from this site have a .part extention???  I am not able to download anything for the past 4 days? ??? ?   WHAT'S UP? ???
Hope, I was using firefox 8.0 at the time of the forum's software upgrade, that is when it started. I had to re-download firefox 7.0.1
as a partial work around. Still have some problems like this box I'm typing in wont let me right click. to paste anything in here i use "ctrl v"
also spell correction wont work because right click wont work. but at least files download correctly now. :-\ nice upgrades ::) ::) ::)
wings
Quote from: verpies on November 22, 2011, 07:36:30 PM
In the STAAAR device the magnetic H-field is 2-dimensional because it is created by perpendicular windings.
Your drawing below does not show that.
...but it does show correctly that the E-field created between the surfaces of the capacitor is perpendicular to one of the the H-Fields.
Actually the E-Field is perpendicular to both of the H-Fields but the drawing does not show that either.
This creates a 3-dimensional mutually perpendicular field vector arrangement (two H_vectors + one E_vector).
Of course if you are not paying attention to the phase difference of the two perpendicular H-fields then you might create the 2D rotating H-field by chance only.
similar to Bearden concept:
http://www.cheniere.org/misc/static%20poynting%20gen.htm
added
http://www.ngpedia.ru/id528540p2.html
TEP
http://jnaudin.free.fr/html/teppicts.htm
