0 Members and 81 Guests are viewing this topic.
baroutologos
Quote from: verpies on November 22, 2011, 06:29:16 AM
@Baroutologos
If the LF was fed by a high impednace source into a low impedance winding @ 300Hz and the LF voltage amplitude across the winding did not follow the I*Z relation, then indeed this was some unconventional ratcheting effect.
@All
For those who do not know what a ratchet is, see:
YouTube Ratchet
Yes, i can understand what you say Verpie. Actually an spark-gap HF wave injection qualifies for an higher impedance source in relation to slower wave (LF) made by a lower voltage oscillator.
Also, for an oscilogram such as this to see, the HF wave should produce a lower amplitude wave on that core than the LF one. (even though its source to be of higher impedance in order to force it be shown there)
jbignes5
Quote from: Magluvin on November 22, 2011, 10:21:44 PM
Are we talking about any event that happens under 2khz?
Sine wave through a coil? Square? Pulse? Unidirectional pulse? 2kw amplifier into a wall of 10 inch woofers at 35hz? 50kw amp(s) wall-o-subs, 60hz pulse, 170db?
Or are we only talking about using quenched spark effect?  Are you guys quenching? hmm?  ;]
We live in a sea of 50hz/60hz. Both within the range you specify. How long do we have?  ;]
From what I read, not from TU yet, is that the effect(s), only happened when the source "high tension" is discharged into a stout conductor, in a unidirectional fashion, via quenched spark, or, like Edison, connect a 4kv running generator to the mains.
I remember Otto, he had experienced some of these things. Jimboot posted not feeling well from running his version of the Ossie motor.
Also, from what I understand here, is that the 50hz injection is not really anything like what Otto or Jim was doing. Unless the spark discharge is at 50hz, of which, im not familiar.
Mags
I think cell phones are 1 thing common thats way under regulated. over 2khz.
I was talking about the 1 turn copper/aluminum strip. That is being pulsed in a capacitor discharge for a longitudinal pulse. This is the dangerous part. And to a lesser degree mains 60 hrz is not a good thing. Have you seen the emf device, we have to see if grounding is an issue in order to get rid of these bad fields.?? Yes it is unhealthy for us yet this is what we got pushed on us.
Even if they are not quenching the gap it is still producing the effect just not as strongly. When they went away from the gap then they had trouble getting the device to work.
You can actually think of this pulse as a polarized surface and it doesn't react to a 90 degree polarization. So in effect we have 3 polarized surfaces. Two conventional em fields and one longitudinal surface polarized from inner to outer of the ring.
Ok so does everyone understand what the longitudinal pulse does? Think sonar but without reflection. The source is the copper/aluminum strips you are using. Also think that this pulse will reflect off of the same emitter if it is charged. When it is charged it adds more waves to the iron. Aether does react to Aether if it is charged at the same level. Don't think of the iron as a conduit of this Aether. The resonance you want is the timing of the pulse reflecting off the other end of the strips. Once this surface is created we need only stir the pot. Tesla did this in a bidirectional way. It's easier to turn a steam valve with two hands instead of one. Also Tesla seemed to be able to tap the spin of this surface through the use of the bifilar coil. This coil will allow you to attach to a pressure in a diode like fashion and inject spin and instantly recover all the energy and even some more. It is the same concept Leedskalnin was looking at. The permanent magnet holder is this event. It will last forever and it acts like an accelerator. You guys might want to try a few self shorted ballast winding's around the yoke, it might increase the surface strength.
I would also try using bifilar winding's all the way around making sure you follow the turn rule to take of the decoupling with the source supply. The direction of wire around the core is very important make sure it runs the same all the way through the device.
wattsup
Quote from: baroutologos on November 23, 2011, 02:24:32 AM
Anyway, this is a strategy too :D
Sneaky is good. lol
wattsup
@all
Pulsing the 1T?????? At low levels, I think you will get more effect by removing the negative of the pulse generator and pulsing the copper strip on one end only. I am getting 4.0vdc on Load Group off the 150T with only the 1T pulsed at 25.4MHz. Never got that before. I had a bite a 7.2MHz (when the negative was connected) but nothing like this. Without the LED it  holds at 12.9vdc. When I connect the other side of the copper strip to a wire going to my ground water pipe, this adds a good 0.4vdc under load. Hmmmmm. Very TKish.
I think also I will try and cut the copper strip at the return point and use each (inner and outer strip) separately or in reverse connection. This is a variable that was not really looked at.
@verpies
I am thinking of making this operate with a 12 vdc battery (7ah) or two in parallel.
I'll see what I can do, but there are some things on the diagram I am worried about. Mainly the zener diodes seem to be pointing to the gate feed and I am worried about that. Using 10 volts zeners I would rather have them pointing to a mutual or two individual holding capacitors then put a 50 volt zener from there back to the battery.
wattsup
jbignes5
Quote from: wattsup on November 23, 2011, 09:10:10 AM
Sneaky is good. lol
wattsup
@all
Pulsing the 1T? ??? ?? At low levels, I think you will get more effect by removing the negative of the pulse generator and pulsing the copper strip on one end only. I am getting 4.0vdc on Load Group off the 150T with only the 1T pulsed at 25.4MHz. Never got that before. I had a bite a 7.2MHz (when the negative was connected) but nothing like this. Without the LED it  holds at 12.9vdc. When I connect the other side of the copper strip to a wire going to my ground water pipe, this adds a good 0.4vdc under load. Hmmmmm. Very TKish.
@verpies
wattsup
Yes low frequency was what they were using. 50hz right on the 1 turn pulsed trough a spark gap into the strip that is wound around the core? You know I think that both these fields do work in similar fashion. Although they are out of phase they are not out of sync. Effect one and the other responds. This is the bemf we see in coils after they have been pulsed. With the advent of bifilar coils this gets harvested in the form of speeding up the energy that flows in the coil in one common direction and increasing it's voltage potential in the process.
We could see the magnetic field in a round about way and said thats all to it. In reality there is a counterbalance and they both get effected at the same time. What the proportions are remains to be explored but I think we can come up with a way to turn it all in the direction we want and to focus it to do our work. We have to stop thinking it is all about matter and start seeing the truth of it all.
Two forces of equal but opposite sex and a boundry in between those sex's. One initiates and the other follows. Learn how to move the one who initiates and you have plentiful energy as a response, for every human being on this planet. Each with their own surface to modulate and extract their desires from.
Free energy isn't just a technology it must be a fundamental change in all of our lives. It will cease all greed because every single person will have the ability to enact change. It will empower us to grow in ways we can only dream of now in a way that will be abundant and lasting. Yes it is gonna be a shock and some people might not want to do anything more then live their lives but they will be truely free to choose that path. It won't matter to the guy down the street if I don't do anything for the rest of my life but what I do here. For me this is my passion. I like looking deep inside and seeing the process for what it is. Energy is forever and we are quite the energy machines.
Lets move beyond our greed and figure this out for real. We have many clues now and should be able to go where others already have gone. Tesla laid it all out for us to experience for ourselves. We just got to want to do this and really learn the truth.
verpies
Quote from: American on November 23, 2011, 04:30:06 AM
to all,
I have been lurking on this thread for a while, and started playing around trying to simulate the effects via an online java based circuit simulator.  (www.falstad.com/circuit)  i was able to duplicate the VLF signal (in my case 12kHz, (but it worked at many other freqs, even those not an integer multiple of base freq)), "riding" instead of being modulated by an ELF signal (60 Hz in my case).  I don't currently have the time to build the circuit to test the theory in practice.  I designed the f0 of the output to be at 24kHz, and used input frequencies (12kHz and 60Hz) that would evenly divide from it.  I hope that this helps with the circuit designs.
Are those ideal AC voltage sources?
If "yes" then for the simulation to be realistic, add 50ohm resistors in series with the AC voltage sources.
Also, what is the inductance and resistance of the primary winding?
Are both halves of this winding the same?
