0 Members and 235 Guests are viewing this topic.
Collapsingfield
@T-1000 - Just a simple question. Please give us the setup of your generator at your new video:
Must have step for your OU devices - http://www.youtube.com/watch?v=yvb6owE05TMWhen you get non-decaying self osccillations, you're on [color=rgb(0, 0, 255) !important]the right[/color] way..
wings
Quote from: verpies on November 24, 2011, 08:05:35 AM
If my hunch is correct than the goal of the tuning procedure is to create a rotating magnetic field inside of the ferrite. See the animation of it here:
The animation above uses 2 pairs of windings (4 windings), but it is possible to create the same rotating magnetic field only with 2 perpendicular windings (see the attached picture).
Anyway, to accomplish the above objective, at least two perpendicular windings are needed. If two of them are used then:
with electronics Differential Audio Phase Shifter circuit  R. Andersen
http://electropub.files.wordpress.com/2011/07/rotating-magnetic-field-using-4-coils-wrapped-around-a-ferrite-toroid1.pdf
verpies
Quote from: wings on November 24, 2011, 09:55:10 AM
Yes, a kHz-MHz Oscillator + Differential Phase Shifter circuit + two HF amplifiers would work, too.
This is the driving method that I meant in the pt 2c_i below
         i) Driving the windings by two separate low-impedance AC voltage sources (signal generators + amplifiers) outputting two separate waveforms of the appropriate phase difference.
There is one gotcha though: the LCR phase shifts from the two perpendicular windings still would have to be accounted for.  That's why I wrote "appropriate phase difference", not - 90deg.
This does not matter if the windings are constructed identically (the same number of turns, shape, wire, spacing, core, etc...) and their phase shifts are the same, but it does matter very much when the windings and their phase shifts are different (as in the STAAAR Yoke device).
Methods 2c_ii and 2c_iii cannot operate at true resonance frequencies by definition, because at LC resonance the phase difference between current and voltage of the signal generator is 0deg.
The method 2c_i allows for the operation at true AC LC resonance, thus it should be much more efficient.
LtBolo
Quote from: verpies on November 24, 2011, 06:46:24 AM
What's so special about the ascending voltage amplitude in an LC tank, driven by a signal generator?
Resonant rise decreases with each wave as it approaches a maximum related to the input energy and the Q. Its envelope is shaped more like a capacitive charge graph.
Their waveform was increasing each wave as a percentage of the previous wave...a trumpet shaped graph. Not necessarily free energy, but definitely not just resonant rise. If the load on the signal source stays constant while that waveform is happening, that is a very good sign.
stivep
http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg306398/#msg306398
Please read again my  long statement from page 602 and with all of the recent  changes
It is very important to read it carefully.
We might or we might not be at the edge of explanation of some of weaponry or some of factors if these factors have been ever felt by anyone on the battle field or any other place anywhere,
We might also prepare you that if you have  these  side effects  to properly understand what  it may come from.Wheter you have these felling in battle field or group protests as public expression of their opinion .
I just finished  it.
symptoms:
-pain in the part of the head. Felt similar to mechanical impact.
-Pain felt as  skin affected when you move your head rapidly.
-lose of  patience.
- pain is not felt immediately but after few minutes of exposure.
-undefined feel of body discomfort.
This  effect was  expressed by all of the people in the team that was total of 4+ 3
Wesley
