0 Members and 400 Guests are viewing this topic.
T-1000
Quote from: Kator01 on November 26, 2011, 07:17:23 PM
T-1000,
looking at the last diagramm of Naudins Website:
Why didnt he continue and increased the frequency to the point of matching the cut-off point of the square-wave-puls  with the beginning of the "soliton"-undamped group ?
Don't know but those "Soliton pulses" are where resonance occurs and need to be supported - just with AC signal. Also his Caduceus coil got 7 intersections, not 5..
MeggerMan
Hi T1000,
I have not followed all of this thread, but what happened to the TV deflection yoke idea?
Has this been superseded by the pipe former and ferrite core?
In the youtube video the 100watt bulb is being powered by the output coil, do you know what the input power was?
The input appears to be a pulsing of the TV HT transformer in series with a spark gap and the primary.
Is there a copper shield in the pipe core setup?
Meggerman
verpies
Quote from: xenomorphlabs on November 26, 2011, 11:29:24 AM
Floyd Sweet's coil arrangement (that he originally tried to show as his magnet conditioning set-up but is more likely the pickup arrangement) has a resemblance of what you have shown in your pictures.
This is the minimal arrangement of windings/coils that will create a rotating magnetic field when the currents in those windings are sine waves 90deg. out of phase to each other.
Also, because one coil, on that picture, has many more turns than the other, then this implies that the coil with less turns had a capacitor connected in parallel to it and both windings were driven from the same AC voltage source as described in methods 2c_ii or 2c_iii.
The method 2c_i, however, is much easier to tune and more efficient. It requires a Quadrature Oscillator, though.
I have seen an arrangement of such perpendicular windings spin a levitated spherical magnet to such angular velocity that it shattered.  There was nothing unconventional in this experiment.
I find it interesting that these crossed windings are enclosed in what seems like carbon-fiber box (an expensive material known for its strength).
Also, according to conventional theory, rotating magnetic field should "blow" any ionized gas or electrons through that box just like a fan blows air.  This is easily explained by Lorentz deflection of electric charges q(vxB).  This is conventional behavior, too, but I have never witnessed it firsthand.
If the box was capped off at its ends with metal caps (not shown on the photo), the Lorentz deflection of the rotating magnetic field should separate the positive and negative charges floating in that box (positive charges to one cap and negative to the other), thus creating very high voltage between those caps.
This is also predicted by conventional theory.
verpies
Quote from: MeggerMan on November 26, 2011, 07:51:35 PM
Hi T1000,
In the Youtube video the 100watt bulb is being powered by the output coil, do you know what the input power was?
I would like to know the answer to these 3 questions, too.
I asked two of them several pages ago, but they were ignored.
Also, after watching the videos, I am not sure what power source exactly, powers the TV Flyback
I have never seen simultaneous scope shots of the input current and voltage or anything that would give a good indication of the energy flowing into the device.  I have seen the power rating of one transformer (9V 600mA AC) but I don't have sufficient information to analyze what part of the input power flow limit that might represent.
Anyway what happened to the STAAAR's Yoke device ????
T-1000
Quote from: verpies on November 26, 2011, 08:35:33 PM
Anyway what happened to the STAAAR's Yoke device ??? ?
As we stated, there is problem with ferrite core becoming permanent magnet and getting decreasing efficiency after each degauss.
We will continue working on it and hopefully will overcome this obstacle.
