0 Members and 153 Guests are viewing this topic.
energia9
Quote from: abc on November 28, 2011, 12:42:20 AM
verpies, you can not win, it useless to prove anything to uneducated people,
let them play their game, they're very-very wanting to be on the top of the world - "working OU", it's not OU, and it's not working, and it will never be, and it's not me or you, it's a Physics;
so just don't waste your time, it's useless, some of them already know it but just don't want to admit it.
Hope, it's open forum, you can agree or not, who cares, you like it - so, it's you, but you can't change mind of others, can you :) . Don't bother to answer, cuz I won't reply,  I'm just supporting those who has a clear mind.
what does it mean to be uneducated??  not listening to the bullshit that they stuff into you in college?  the world is more than they tell you friend, time for a wake up for you, your belief system will collapse under your pants.
physics as they know will not exist anymore
you are supporting those who dont want to make a better future,
the books that they put in front of you have all been designed in the way that if you seek to know truth  you will just believe them with your mind because they are presented ''professional''  with professional seeming truth, you will just believe every government funded agenda because your mind have been designed by them from your childhood,
   todays books tell yo how to support the current system,  they will never tell you to invent something new,
BECAUSE THEY DONT WANT NEW!
they want CONTROL And they keep truth to themselves, oh friend if you would know how much a human life counts to these people....   NOTHING not even a penny.
In medieval times the earth was flat...   and they burned those who said round.
this society is based on fear, fear of knowing the real truth, which has nothing to do with belief systems.
jbignes5
I'm going the route of what has been patented by Tesla already. What more credibility does one need? Everything has been worked out for you. Tesla said this was an improvement to the AC system he invented in the past and sold to Westinghouse.
Also the Iron was mentioned in either a lecture or book and I WILL find it. Tesla said laminated iron did better with higher frequencies. Especially for the soft iron types. I guess any really good soft iron would do. I got to inquire about what kind of iron I bought at the shop down the street. I had a 10" diameter hoop made of 1" soft iron split in two halves. Just like the yoke.
I'm gonna use very thin gauge wire to wind the filed coils. They are only gonna take so much force then give so not too small a a gauge. The exciter is gonna have very fine gauge to generate from so it's intensity should get up there and excite the fields around the generator coils of the rotor. This should cause the other portion of the network, the current, to start churning in a vortex with a rather different response. Remember we cant have one without the other moving. They respond from the same spot or origin. Tickle one and the other responds as well. You just need to know how to harvest the vortex in the proper way.
Think of it this way. Through induction we are creating a one way flow via intensity. If the heavy magnetic field induces to the high voltage windings they go up in intensity and contain the field with no breach of any kind. This allows it to push without a push back in effect. Or more interestingly they push back with a converted higher potential or voltage, simply via induction rules. So in it's steady state it is in balance only giving what it needs to self sustain. Any checking or slowing of the rotor increases the response from the field coils and induces more current as it gets out of phase with the vortex. You could call this out of phase a slip, so to speak. The more you slow the rotor the more current it pulls in like a valve opening to maintain it's balance.
It is this motor I believe Tesla went back to after his lab burned down. He knew wireless was dead so he needed to pull out the ace up his sleeve and use the personal generator.
*edit* The metal was not iron but Bessemer Steel!
Here is the link:
http://books.google.com/books?id=KRg9HWakBmQC&pg=PA64&lpg=PA64&dq=tesla+gave+westinghouse+new+soft+iron+for+transformers&source=bl&ots=0SjD0CgTBB&sig=oZ-dIBnH9jnWaT_688Dtm0YWvso&hl=en&ei=upTTTszED6Xf0QGl3qxL&sa=X&oi=book_result&ct=result&resnum=4&sqi=2&ved=0CFQQ6AEwAw#v=onepage&q=tesla%20gave%20westinghouse%20new%20soft%20iron%20for%20transformers&f=false
But Tesla says it was mislabeled as steel. In reality it was soft iron...
Go to page 75 and read it. You will see that Tesla says we were lied to about this stuff and taught what they wanted to work, for which they could charge for.
wattsup
@T-1000
Given the last three WNY videos, of course I have so many questions to put forth but do not dare put them all since the discussions are just going all over the place.
But, if possible, can you please try this on the device or maybe it has already been tried.
On the CC output coil, the center tap between both bucking coils was always connected during the videos where I saw you guys trying various output connections. But did you try as I show below. I made a diagram to explain without need for Russian translations. lol
I would really like to know if the output is the same when you do Alt. 1 and if output can increase if you use Alt. 2. I am curious that the left output coil is more or less not used (open ended), or, is the second open ended coil the reason you get the trumpet effect on the scope. I would like to know if there are  differences just to be sure.
Regardless of what anyone says as critic, you cannot really critic pioneering works. Just ask more questions to know more of the variables like you guys are already doing so well.
@stivep
Get some rest man and don't waste anymore energy on frivolous matters as this is only eating away at you for nothing. You need to preserve your energy because without you, the link is broken. It is not your job to respond to every little quibble. If people think they can demand progress, then let them just think what they want while you guys take care of the heartless reality, like getting shocks.
I'm almost ready to run the flyback again. Anyways, since I am in North America, I thought it appropriate to make the Flyback and drive look Chopper style using that circuit. I'll see how it runs soon enough once I finish the connections. Orange County - Eat your heart out. lol
@verpies
About that circuit, I stopped going further because I am having trouble figuring out which way the zeners should point and the other two diodes as well. Is it possible to indicate this better. I mean, I think I know how they should go but I just wanted to make sure. Also, why is there no flyback return diode going to the battery +. Why does it have to return via the 470 ohm resistor? Seems to me the zeners should land directly on the B+ and not on the gate. I will wait in case there are any changes to that circuit. maybe you can explain the uses for all those components including the D1 to D4.
wattsup
stivep
Quote from: Shokac on November 28, 2011, 04:12:59 AM
Thank you for using my approach!
The only thing missing is a constant source of VOLTAGE  (sugest 220V or 110V from inverter)!!!!
in regards to power usage of the device please read carefully,my post
http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/9165/
Thank you my Friend Shocac.
Make device and show  to the people so that would be less questions of the basic nature.
Your contribution will be of much help and will be memorized.
I'm having privilege of directly  contacting with Mr. Kelly... The history file is waiting for you.You the son of Tesla Nation.
I have no questions to your schematic.
Vladimir Utkin  is writing to me and he gave me his telephone contact. That stays about validation of the concept by  Vladimir Utkin by himself.
Quotequote:
On Sat, Nov 26, 2011 at 3:10 AM, Vladimir Utkin [/size] wrote:[/size]
Hi Wesley,
I see you are online..
Are you in Europe?
GOOD VIDEO!!!
Regards,
Vladimir
Tariel Kapanadze did not give you any details  but he is not subject  of criticism   at all.
You need scientific data from him... ask him directly and do not put the pressure on me.
Dr. Steven E. Jones  is interested in this technology as well.
With great  respect that I have to  him I can say that he went through   a lot of  criticism in his life but he managed fighting with trolls.
I do not care about me being exposed to criticism.
-My regular response is try to shut up  trolls.
-Give answer to others
-At the end if criticism will arise I will close doors of my lab  to te public and come out with ready to show and properly measured and documented device.
Universities works years on subject of investigation  of only one of the complex components of project that we have on the table.
2 weeks apart one  from the other we come-up with two different technologies.
-one is based on NMR (or  suggested theoretically)
-second is caduceus with  capacitive coil or regular pickup coil.
We are not being  supported by anyone nor we ever ask for financial support
The demands for scientific data arises placing us in situation similar to  Cold fusion of Dr. Steven E. Jones
The good point is that  I do not have name nor reputation under   scrutiny on the table nor I care about it.
So  you can write what you want I'm coming back to bench and do experiments ,measurements.
this is more influencing than fighting with trolls
If trolls are being politically and/or financially  and/or both   motivated than they  can buy some time but not much of it.
Very much unusual is approach of our group giving all of the important development on the spot right in very minute.No chance for "power owner " is given.
General knowledge  and direction is spread  by hundreds of thousands.
It is not going to die.
That was exactly the same mechanism that works in Egypt.
I ask all of you to start  experiment.
In this friendly crowd there is scientist trying to come out from many of you.
There is motivation, and encouragement.
IT IS GOING TO  COME OUT that is my believe Year 2012 is around the corner.For NEW to replace OLD.
QuoteLegal note:  quote: "start  experiment." means - any experiment in any nature. Keeping in mind safety statements of mine :)
this is added for legal purpose only. :)
Wesley
The choice is yours.
I have noting to lose any longer nor I really care.Life is important but everyone will die anyhow so what the difference it makes? We do not know the day or hour.I can die  any time soon or longtime from  now.
But  when I be pushed to  die I will bait as much as I can.That includes saved data and or information  of certain nature as well.
I can live in apartment  or house with lab
I can be without lab,my friend will help me with his lab, no difference.
As long as I have food and any car at all, or public transportation in convenient place. I'm, I say happy.
But not everyone is happy heaving such strict ,life style. Now you understand why money can not buy me.
