0 Members and 450 Guests are viewing this topic.
wattsup
@all
We have lift off.
Man does it rip or what. That spark gap is roaring and the air fills with ozone within 5 seconds.
I changed the circuit, zener in series, uf4007s, irfp260npbs, I re-wound the two primaries with magwire to et more direct contact but i put a plastic transformer material on the core first, my diodes are working ok. I put the capacitor only on the breadboard to add or replace values. Now I go to sleep because it's 3am. Fun tomorrow.
wattsup
TEKTRON
Quote from: zhak on December 01, 2011, 02:36:35 AM
good day
Explain what this stuff?
mica, aluminum foil, broken capacitor?
thank you
Ð"обрый день
кÑ,о знаеÑ,
поясниÑ,е какой эÑ,о маÑ,ериал ?
слюда, алюминий Ñ,,ольга, разобранный конденсаÑ,ор ?
спасибо
Hello, It is my understanding that it is aluminum foil tape with an adhesive back. The protective paper was left on the foil. Clear plastic package packing tape was added to improve the insulation. The added plastic tape does reduce the capacitance as a side effect(wanted or unwanted ?) I think. The aluminum tape is commonly used on HVAC systems on the plenum.
Tape here --> http://www.google.com/products/catalog?q=aluminum+tape&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&channel=np&um=1&ie=UTF-8&tbm=shop&cid=18001265940228879997&sa=X&ei=mDnXTqSbLLDMiQKW0v3dCQ&ved=0CHQQ8gIwAA
TEKTRON
Quote from: wattsup on December 01, 2011, 02:53:21 AM
@all
We have lift off.
wattsup
Cool, Cant wait to see your results. I really need to get to get off my @ss and build as well. I hope your FBs work out because I bought the same ones from your link ;D
verpies
This circuit is powerful enough to damage your small flyback transformer. Bigger ones are in big old CRT TVs often sold at garage sales.
What are these white cuboid parts between the gate and source of the transistors?
Are they the 10kOhm resistors?  If "yes" then to me they look like the inductive type, and that's bad.
At 10kOhm and 16V, the current through them is so low (1.6mA) and power too (2.5mW), that you can safely use smaller low-power 1/8 Watt carbon resistors in their place.
If you want to vary the circuit's C1 capacitance, solder the smallest HV MKP capacitor you have, as close as possible to the primary winding, and add larger capacitances in parallel to it on the breadboard if you wish.  Don't put the whole C1 capacitance away on the breadboard with long wires.  It is dangerous to the transistors and may increase EMI and decrease driver's performance.
For more power and different frequencies you can play with adding more primary winding turns (on vertical and horizontal legs of the core as well) but not less.  Less turns can damage your circuit - more cannot.
Your driver circuit should be able to be supplied with up to 50VDC if the flyback transformer can withstand the resulting amount of power fed to it.  Also, watch the temperature of the transistors if you choose to increase the supplied voltage.
Ganzha
Quote from: Ganzha on November 30, 2011, 12:21:48 AM
Tiger used in his Yoke and in Tube devices this schematic I replicated this devices very carefully but I use 2cs5200
I have to point whom likes to replicate Tigers devices - in shematics of this flyback device is one error - there are two identical transistor - instead of couple of complimentar transistor. Please keep it in mind. In graphiucs was "trap for fools"/
