0 Members and 67 Guests are viewing this topic.
xenomorphlabs
@Chet: Good that you wrote that up. It`s a good quantitative method and free from interference due to spark gaps and HF which would occur in any current measurements with non-shielded, low-cost equipment
Keep it up.
Rolling
From other Planet
Uhm sorry but i think this energy metering wont work better than using Light Bulbs. If Output is cold electricity, or a mixture of cold and conventional electricity, measuring using load produced heat wont give useful results. Or am I wrong?
Guess best way would be to drive motor with output, couple mechanical to generator and measure generator output, of course consider efficiency factor of both. Will only work if Device can drive inductive Load.
I am wondering about values of Capacitors and Diodes u use in http://freeenergylt.narod2.ru/lithuania_experiment/sxema_rabociaja_darobotka.jpg (Think u made changes here?):
Variable Capacitor C3 is 27200pF? That's huge!? When u came up with first device, u said 500pF?
C2=C4=3400pF?
HV Diodes, u said 80kV, 1A. I'm close to buying such diodes, but they are very long (12-20cm), them i can see u use in your videos are like 5cm long?
Where to buy these nice encapsulated spark gaps u have?
Thanks, good luck to all with replication
a.king21
Ganzha, It's blindingly obvious that you do not know the difference between a coil and a transistor. And yes we all know where the trap is and I'm not telling you. You are making yourself look very foolish :-[
