0 Members and 163 Guests are viewing this topic.
Ganzha
Quote from: a.king21 on December 01, 2011, 08:47:51 AM
Ganzha, It's blindingly obvious that you do not know the difference between a coil and a transistor. And yes we all know where the trap is and I'm not telling you. You are making yourself look very foolish :-[
In other forum your speach looks quite different, could you explain that?
Hope
Quote from: verpies on December 01, 2011, 04:59:32 AM
This circuit is powerful enough to damage your small flyback transformer. Bigger ones are in big old CRT TVs often sold at garage sales.
What are these white cuboid parts between the gate and source of the transistors?
Are they the 10kOhm resistors?  If "yes" then to me they look like the inductive type, and that's bad.
At 10kOhm and 16V, the current through them is so low (1.6mA) and power too (2.5mW), that you can safely use smaller low-power 1/8 Watt carbon resistors in their place.
If you want to vary the circuit's C1 capacitance, solder the smallest HV MKP capacitor you have, as close as possible to the primary winding, and add larger capacitances in parallel to it on the breadboard if you wish.  Don't put the whole C1 capacitance away on the breadboard with long wires.  It is dangerous to the transistors and may increase EMI and decrease driver's performance.
For more power and different frequencies you can play with adding more primary winding turns (on vertical and horizontal legs of the core as well) but not less.  Less turns can damage your circuit - more cannot.
Your driver circuit should be able to be supplied with up to 50VDC if the flyback transformer can withstand the resulting amount of power fed to it.  Also, watch the temperature of the transistors if you choose to increase the supplied voltage.
Great guidance Verpies,  thank you for helping with your EE knowledge.
Ganhza  your only being given your return negatives,  maybe we should all just keep the N chatter stowed.  No one is ever extolled for what they destroy, only for what they build.
verpies
a.king21
  (http://www.overunity.com/Themes/default/images/icons/profile_sm.gif)
(http://www.overunity.com/Themes/default/images/email_sm.gif)
(http://www.overunity.com/Themes/default/images/im_off.gif)
    (http://www.overunity.com/Themes/default/images/post/clip.gifRe: Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze  « Reply #9323 on: Today at 04:11:05 PM »   Quote
   Quote from: a.king21 on Today at 02:47:51 PM
Ganzha, It's blindingly obvious that you do not know the difference between a coil and a transistor. And yes we all know where the trap is and I'm not telling you. You are making yourself look very foolish (http://www.overunity.com/Smileys/default/embarrassed.gif)
  In other forum your speach looks quite different, could you explain that?  (http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/dlattach/attach/91576/image//) Because I have spent a lot of time checking Tiger out subsequently and talking with an individual who has a working OU device in another field. We are now not convinced. However I am open minded and if Tiger wants to open source like Wesley, I would be the first to acknowledge that. There is no animosity, only science and facts. Don't take it personally. I also make mistakes like anybody else. But remember, in the overunity game you only have to find the correct overunity answer ONCE!
verpies
@Ganzha, a.king21
Do you have any evidence that SAAAR Team's device does not work and Tiger's device works, or vice-versa ?
