0 Members and 463 Guests are viewing this topic.
Hope
I have no flyback at this time.  I do have a balanced 15Kv older neon trafco.  Does anyone know if that will be a good source for this devices HV input?
I also have a "constant voltage" 118VAC Solex and a 45 Amp variac (older broadcast amp equip for GE, it must weigh  80 lbs)
I believe the induction load and generator setup will be a good method of power output verification, at least it is measurable with conventional test equipment most have.
Please, if anyone has priced the super conductor wire for the new device from AK,  what is the pricing and part #.   I suggest we source it from ANY company EXCEPT American Wire (only due to they are very close to Ft Devens where gov has a HQ that watches all communications vocal and data).
a.king21
Quote from: verpies on December 01, 2011, 11:36:55 AM
I and another researcher spent a considerable amount of time trying to duplicate the yoke device. We knew that the original instructions would destroy the 50 Hz generator, so we didn't fall for the trap. Other replicators unfortunately did. When we checked out Tiger's schematics we found a transistor hooked the wrong way round. Subsequently another unfortunate replicator destroyed his multivibrator. That's why I was rough on Ganzha. And so would anyone else having our experience. Then Tiger played a cold electricity scam on a youtube video. It was plain as day that his foil was not connected to anything. I and the other researcher are probably in the few 100 people on the planet who know cold electricity backwards so we were not amused. I could go on, but it does not get us anywhere.
Our preliminary investigations indicate that the Kapanadze replication is the clearest yet, and there's no doubt that Wesley is sincere. Don't get me wrong I've been tough on Wesley also, although in private posts. I don't like people playing games with me and won't put up with it. BTW I checked out SR's replication and found he uses a foil, which I assume to be a capacitor, which is seen in the centre of his output coil. So I'm hopeful about Wesley's team's device.
It sounds and feels right.
stivep
WARNING:
This was a test only
results:
The picture OF MINE - OF  PICKUP COIL below  loads with no problems.
I have one schematic that I'm trying to post on this forum DOES NOT loads
Is says
Failed Security check.
It was taken from FreeenergyLT and redone by me.
http://freeenergylt.narod2.ru/aidas/
The name on it starts from:
Aidas/LITHANIA,Arunas/LITHANIA, Antanas/LITHANIA,Stivep/Wesley NY/USA
This particular  schematic does not allow  me to load to Overunity .com
THANKS TO GOOD PROTECTION.
Any other  file of mine loads with no problem.
I have tried to edit it with paint and made my very valuable copy with descriptions,and changes. re size it I have changed  name of the file.. Did not helped.
I have asked for help  professional and he says that jpg file can not contain any spy module.
My suspicious is that this picture may contain beacon module.reporting IP of computer that has it  downloaded.
Please who ever is knowledgeable in this area to respond
Please check your files for this kind of problems.
Wesley
I WAS FORCED TO MAKE PICTURE FROM THIS SCHEMATIC ( REDONE BY ME) USING MY CAMERA ,IN ORDER TO BE ABLE  TO POST IT.
PLEASE  VERIFY THE PROBLEM
IF SUSPICIOUS WILL BE CONFORMED THAN WE ARE DEALING WITH REAL PROBLEM HERE.
HARTBERLIN PLEASE REACT
Wesley
jbignes5
Ok for people who want to see this field in motion look at this. http://www.youtube.com/watch?feature=endscreen&NR=1&v=HWj8ezZZyYc
This is the prime example of what we want to do. The vortex is also seen in this.
Also this will let you see what is going on electrically on magnetics: http://www.youtube.com/watch?v=0d6chzb7Z1c
And this one! http://www.youtube.com/watch?v=NBXMG72gfqs&feature=relmfu
verpies
