0 Members and 405 Guests are viewing this topic.
ramset
Wesley
I had a problem loading things here also??
However We should all call [PM] Stefan ,you are correct this needs to be understood ""Security issue""
There are at least three threads at energetic ,Can you see if the problem is there also??
Thanks
Chet
PS
BTW
Your Schematic is Beautifully done [very high score..........]
Thanks Grandma
TEKTRON
Wesley, is that the filename? "Aidas/LITHANIA,Arunas/LITHANIA, Antanas/LITHANIA,Stivep/Wesley NY/USA.jpg"
Dont think you can use" / " or " , " in a filename
jbignes5
Quote from: verpies on December 01, 2011, 01:36:20 PM
Rotating Magnetic Field again...
Rotating how about cork screw like. And that was just from two sets of magnets. Some of them are from 1 magnet and one is even a Christmas spelled in wire that shows the vortex in action. It is not just a rotating field. They have layers and I suspect that it is from an interaction of the two fields. One being voltage and the other magnetic.
Now think of this field around a circle of iron with energizing coils. We should use high voltage around the field coils this will cause the layers to move like a Caterpillar around the circle. The out side of the field ring will be less constricted then the interior, which should be massively constricted and this is where the flow comes from.
Since Tesla messed around with tubes and vacuums he would have figured this out back then and designed a motor to interact with precision in the fields that he saw. along with the Bessemer steel which gave him more permeability (2.5 times) He could easily have gotten more out then in.
These are not just rotating fields, They have layers and twisting geometries and we need to know this in order to make the best coil reaction.
MAybe this old timer can help you understand. http://www.youtube.com/watch?v=afQW8FT02DM&feature=related
With this knowledge we can see why Tesla's magnifying transformer did indeed amplify through the use of bucking fields. Now that we know their direction and flow we can devise ways to extract this spin passively like the bifilar coil ???
It also explains why Tesla didn't use a core and only used coil on coil. 1 bifilar wrapped over two separate bucking coils. It would be better if you had two halves of core, one for each coil then it should be amplified in the middle of the cores where you could wind the bifilar onto a non magnetic form in between the cores.
Heck for that matter why not get rid of the cores and use magnets??? Since the field is rotating then it should pick this up seeing that they are rotating.
stivep
Quote from: TEKTRON on December 01, 2011, 02:04:56 PM
Yes that is  the one
I was trying to load it as attachment to email does not work
Wesley
http://freeenergylt.narod2.ru/aidas/
Try to go to web above, and try to  "slide" this  schematic to your desktop that  post it  on overunity
I do not believe it is overunity problem but good security of overunity made indication of problem.
I want to find out if it is  Spy module
Wesley
