0 Members and 312 Guests are viewing this topic.
Magluvin
Quote from: verpies on December 01, 2011, 04:03:13 PM
Thus, a spyware executable code is definitely possible in photo/image files.
Ive read of this. Very interesting.  But are the picture viewing programs designed to be subject to data embedded within a picture file other than just showing the picture?
So, you could use a paint program to soften, then sharpen, to distort the code, yet still get a decent picture.  ;]
Mags
verpies
Quote from: Magluvin on December 01, 2011, 08:11:13 PM
Yes, because photo/image files have headers that need to get parsed before the bitmap data is even located within the file.  These parsing routines can be erroneous and start executing the data in the file instead of just parsing and displaying it.  For example scroll down and see the internal structure of the simplest uncompressed image file (the MS-bitmap):
http://en.wikipedia.org/wiki/BMP_file_format
verpies
Quote from: wattsup on December 01, 2011, 07:52:56 PM
The PS shows 11.5vdc at 0.79 amps but that changes when I add or remove caps, which is also normal. But no HV.
So I am sure the circuit is OK.
I am not.  You had over 5A before. I assume that was with an open HV secondary which presented no back EMF to the primary.
The waveform on the scope is not symmetrical. A symmetrical circuit like that should produce a symmetrical waveform.  Maybe only one transistor opens all the way.
66kHz without C1 ?
Kator01
Hey wattsup,
I think you have blown your secondary.
naudin gave some hints to check if your secondary is ok. In your case you might use a lower voltage and polarity does not matter, as you do have the hv-diodes outside:
http://jnaudin.free.fr/lifters/labhvps/tht.htm
Kator01
@verpies
When connected to the power supply, with my scope probe on each of the drains, I get the following waveform, taken chB, 5v 5uS, 1x. WhenI add a capacitor on the BB, the waveform stays the same but the frequency drops. This shows both circuits ends are working and the primary gets a little hot. The PS shows 11.5vdc at 0.79 amps but that changes when I add or remove caps, which is also normal. But no HV.
So I am sure the circuit is OK. It's got to be the flyback.
I think I will have to write a song about flybacks. Maybe call it "Try to survive".
Look at the photo of that TBE-110 taken apart. That's one big hog.
Eventually, if I can only find the schematic to see if that HV negative is on a pin or hardwired.
wattsup
ramset
test
From user Turian
over here
http://www.energeticforum.com/renewable-energy/9673-wesley-stivep1-video-high-voltage-frequency-ou-7.html
HMMM
I see images didn't make it thru??
Very Simple set up Have a look.........
http://www.energeticforum.com/attachments/renewable-energy/9737d1322791173-wesley-stivep1-video-high-voltage-frequency-ou-french-patent.doc
There is a French patent application number FR2680613 dated 19th August 1991 entitled “Activateur pour Mutation Isotopique” which provides some very interesting information. The system described is a selfcontained solid-state energy converter which abstracts large amounts of energy from an ordinary iron bar.
The inventors describes the technique as an “isotopic mutation effect” as it converts ordinary iron (isotope 56) to isotope 54 iron, releasing large amounts of electrical energy in the process. This excess energy can, they say, be used to drive inverters, motors or generators.
The description of the mechanism which is being used by the device is: “the present invention uses a physical phenomenon to which we draw attention and which we will call ‘Isotopic Change’. The physical principle applies to isotope 56 iron which contains 26 protons, 26 electrons and 30 neutrons, giving a total mass of 56.52 Mev, although its actual mass is 55.80 Mev. The difference between the total mass and the actual mass is therefore 0.72 Mev this which corresponds to an energy of cohesion per nucleon of 0.012857 Mev. So, If one introduces an additional 105 ev of energy to the iron core isotope 56, that core isotope will have a cohesion energy level of 0.012962 Mev per nucleon corresponding to iron isotope 54. The instability created by this contribution of energy will transfer the isotope 56 iron to isotope 54 causing a release of 2 neutrons.
This process generates an excess energy of 20,000 ev since the iron isotope 54 is only 0.70 Mev while isotope 56 has 0.72 Mev. To bring about this iron isotope 56 conversion, we use the principle of Nuclear Magnetic Resonance.”
The practical method for doing this is by using three coils of wire and a magnetic-path-closing support frame of iron as shown in this diagram:
(http://www.overunity.com/file:///C:/Users/chris/AppData/Local/Temp/msohtmlclip1/01/clip_image002.gif)
In this arrangement,[/size]
Coil 1: Produces 0.5 Tesla when fed with DC, converting the iron bar into an electromagnet
Coil 2: Produces 10 milli-Tesla when fed with a 21 MHz AC sinewave signal
Coil 3: Is the output coil, providing 110, 220 or 380 volts AC at about 400 Hz depending on the number of turns in the coil
This simple and cheap system has the potential for producing substantial energy output for a very long time. The inventors claim that this device can be wired to be self-powered, while still powering external devices.
Coil 1 turns the iron rod into an electromagnet with it’s flux channelled in a loop by the iron yoke. Coil 2 then oscillates that magnetic field in resonance with the isotope 56 iron atoms in the rod, and this produces theisotope conversion and release of excess energy. Coil 3 is wound to produce a convenient output voltage
Chet
Thanks Grandma
