0 Members and 406 Guests are viewing this topic.
baroutologos
Quote from: Magluvin on December 03, 2011, 05:24:33 PM
Here are 2 very short vids, that since we are varying the circuits a bit, I think they belong here as a simpler alternative.
I believe its Russian. If someone can interpret what he says about the split copper pipe inside the coil, it would be much appreciated.  ;]
First vid is the showing of removing the split pipe with a ferrite rod inside a , what seems to be a Tesla coil config.  The second is lighting a 50w 230v bulb.
I just cant understand the connections made with the split pipe.
http://www.youtube.com/watch?v=Ih8vsrUDEu4
http://www.youtube.com/watch?v=mFn4nMRZoEg
These are very recent vids and here is his channel.
http://www.youtube.com/user/VADIKGUK?feature=watch#p/u
Mags
This is clearly a kacher system. The ferrite core lessen working frequency. I do not think it does nothing more in that system. i have tried that. The inside copper slit tube, acts as a capacitor between the HV charged windings and ground there fore is able to light the bulb. No OU in such system in any way. It should input at least double power than bulb's output.
bolt
So lets assume the lamp is lighting up to about 40-50 watts. By your estimate the simple low power Kacher circuit is in fact consuming 80-100 watts??? I don't think so i bet it about 10 watts and no more than 15 watts. This provides a COP of around 4 which i consider normal for this type of system.
BTW for those that asked the copper pipe cap IS connected to the lamp and DOES form part of the circuit as an ionisation chamber wave-guide part of the Tesla Patents.
BINGO!!! in his youtube notes he says at 12v battery let's assume 12.5v = Current consumption 1.11 ampere = 13.75 WATTS to light a 60 watt lamp to good brightness perhaps 40-50w o/p So my judgement was bang on correct:)
baroutologos
@Bolt,
You assume a cop of 4 that is normal but i find it quite ubnormal. Actually in a Kacher setup the 0.4-0.6 COP is normal.
In your possition i would not believe every claim i see on the internet... :)
Still if you think it that evident and true, i wait to see your self runner :D
forest
wait wait I saw that in stiveip video ! he mentioned that flyback core MUST be GROUNDED or no effect at all. where is that ground coming ? isn't that connected to output capacitor ?
