0 Members and 344 Guests are viewing this topic.
wattsup
Quote from: Hope on December 03, 2011, 11:19:47 PM
Really though can I use a 15Kv balanced neon trafco for my HV inputs?   Anyone?
@Hope
I don't know if you can get it working at up to 20kHz.
@verpies or @all
Here is a tricky one. Just trying to think out of the box regarding the FBT.
We all have easy access to standard flybacks with internal diodes. The last one I showed had three. If the WNY system could be run with these, then the advent would be more widely available. But the problem of the output diode still persists and this changes the HV output from what the WNY guys are producing before the HV hits the HV diodes.
I am thinking what if I put two such FBTs on the same drive circuit. Instead of running the two 6 turn primaries on one FBT like on my last one, I just connect the two primaries of the FBTs. But then can I put the two HV outputs together to then go to the HV output diodes. Would this be close to running it as HV AC just before the diodes? Or, is it also possible with this method of dual FBTs that I would then not need those two HV diodes to rectify? I am just trying to get my head around the theoreticals before I attempt it. lol
wattsup
xenomorphlabs
Quote from: semenihin-77 on December 04, 2011, 08:34:41 AM
Delamorto open left half of the patent Kapanadze
http://www.youtube.com/watch?v=BZaUfuNt-eY
http://www.youtube.com/watch?v=DS6vbvYg9YM
http://www.youtube.com/watch?v=j069BWo5CxE
This Kacher pump, it pumps energy from the earth
If the frequency is that high like Bolt sais (hundreds of MHz), then this thing could pump energy
from the air. No earth needed. He does mention however a ground connection (заземление) in the video
качер и заземление мануал.wmv
(Would be interesting to know what his drive circuit is. Waveform, frequency?
He has a vid called Noise generator in his upload section.) -> Kacher
Seems like it's only using a single TO-220 cased transistor for switching.
The whole thing looks a lot like Slayer's Exciter with the pancake primary.
I built one too back in the days and if i remember correctly it was running at 1.2 MHz
in resonance mode, but here it is either driven by a signal generator or really like the Brovin kacher
just hooked to a battery (which maybe the black block sitting behind the coil).
Since he uses that battery in the other vids too in that way, this is then most likely.
semenihin-77
2 Battery voltage 8 + 12 volts, the current consumption of 1.1 amps Kacher. As you can see Fiton Kacher, a lamp electrically connected to Kacher. Since the dimensions are very small Kacher Delamorto uses ferrites. Everything in the video is based on the patent Tesla, namely utilization of radiant energy.
semenihin-77
xenomorphlabs  !
Yes, air pumps, too, but much less power, and performance tuning is not possible, as a ground wire. The use of the land helps precisely control the amount of injected energy.
