0 Members and 476 Guests are viewing this topic.
stivep
Quote from: Osiakosia on December 03, 2011, 11:51:57 AM
Dear Stivep ,
Please see my U shape coil . Did I connect correctly the ends of this coil ?
Today I tryed to connect generator to whole Yoke system and received ferite
response then put sweep frequency to 15 turns coil and saw the response on U shape
coil .
Must the ends of U coil be connected at the end ?
The best of the best professional in this field would be Arunas form England to answer about tuning of device.
The best of the best professional in practical approach is Aidas Lithuania.
I'm: mostly theory and measurement guy.
I try to help as much as I can :)
If it was me than I would make U shape  with at 100% of with of the  ferrite yoke.
Ends are not important as long as they are from one end of the ferrite.
Arunas if you can please respond  to that
Wesley
semenihin-77
The literal translation of the video Delamorto:
There is connected grounding. Light bulb. Lamp is connected in parallel connected capacitor KPE.Zazemlenie the lower end of the additional inductor.
On the upper end of the additional coil is a copper plate in kachere.Mednaya lining located on top of Kacher,
the entire length of plates do not Kacher nado.Induktor pump red wire is wound in the opposite direction from the second inductor.
Be sure to ground the negative supply Kacher. I kt805am transistor, the bulb 220 volt 60 watt.
xenomorphlabs
Quote from: semenihin-77 on December 04, 2011, 11:26:44 AM
Zazemlenie = Ground (ing)
Mednaya = Copper
So did he just connect the red wire to the copper plate one-wire style?
starcruiser
@xenomorphlabs,
From what I saw the video seems to show a third coil above the pancake coil, looks to be black wire. I believe one is the exciter while the pancake coil is part of the output. It looks to go from the copper plate/tube to the pancake coil then to the bulb which is in parallel with that adjustable cap.is ground then a small length of wire (ground plane)?
Regards,
Carl
xenomorphlabs
Quote from: starcruiser on December 04, 2011, 12:30:50 PM
@xenomorphlabs,
Yes there is a black 3rd coil under the red pancake coil.
One end goes into the core and connects to the copper tube.
Where the other end connects to can't be seen.
Also how the transistor emitter and collector are connected can't be seen.
You can see only that they are connected together via a resistor.
I have made a schematic based upon what i can see in the video, which does
not necessarily reflect what  think this would work like.
