0 Members and 57 Guests are viewing this topic.
bolt
Quote from: xenomorphlabs on December 04, 2011, 08:10:09 PM
@Bolt: It is gonna be hard to rectify a signal with hundreds of MHz due to rectifier switching speed for let's say invert it and feed it back. Maybe some broadcast or UHF rectifiers could work.
Wonder what the voltage range of the signal caught by the copper tube is like.
If the transformer rules are applicable here it would be something like 1000:1 depending on the secondary turn count.
Or maybe it's like in the Zatzarinin Transformer a 1:1, in that case it would be high voltage.
What parameter of the setup could be increased/changed to increase the output to 500 Watt or more like you mentioned? Copper surface area, more ferrite in the core or more secondary turns to create more VARs?
Maybe even a lower resistance ground connection as demonstrated by Kapanadze for a higher current.
Tesla stated :
There is always an artefact signal component in these devices because its required to undergo transformation.  In the TPU it was 5khz.  In the "green box"  its hundreds of Khz and patent shows a low pass filter to get rid of it.  In this device it could be 150-200Mhz but presents no problem to the lamps.  You notice there is one thing missing here? MODULATION. If the kacher is modulated using 50Hz the o/p will be 50Hz in sympathy to allow connection to standard transformers. Now the 150Mhz can be ignored once we already have extracted raw power from the copper ionisation tube.  Wesley has a modulation layer on the 1.6Mhz ferroresonance ferrite carrier but its modulated by 50hz.
My guess is the copper tube is both Homo-polar so it appears as ONE turn transformer as well as a wave guide ionised capacitor. The important thing to learn here is the extraction NEVER actually touches or attempt to draw power from the tesla coil itself. To do so will create a phase shift = BEMF = lugging and < OU.
To increase power of this system = Make a BIG ONE :) Lets say we only get 250 watts? Who cares make 10 of them for 2.5kw. I suggest start small replicate this first then go LARGE, fat earth cable,  3-4 ft tall tesla. Push pull HT driver 50 watts, 2.5" copper pipe inside 3" PVC  drain pipe. Whatever you do you know it can work at 100KW if you go large enough as Kapanadze.
Neo1
Hello Stivep and those replicating the TV yoke ferrite core device
Just wondering if anyone can share with me 3 measurements from a WORKING TV Yoke ferrite core device, as measured across the bifilar coil using a scope.
These measurements would dramatically improve the replication and development process - I understand that there are videos, setup and tuning description's, screen shots and signal generator output levels shared by the development team, however having the following information tabulated would also be extremely valuable to those attempting to replicate this device. I understand that Stivep and the team are extremely busy; If the intention is to share this device with the world it is important to do what is necessary for that to become a reality. For someone with a working device these tests will take only a few minutes.
1) Peak to peak voltage for just the 50Hz 15T coil (Measurement taken across the bifilar coil with scope)
2) Peak to peak voltage for just the High KHz 50T coil (Measurement taken across the bifilar coil with scope)
3) Peak to peak voltage for both the 50Hz 15T coil AND High KHz 50T coil (measurement taken across the bifilar coil with scope)
Many thanks
Neo1
Magluvin
Here are a couple pics of my lil Tc Im getting out to try things.
The one pic shows the top secondary lead inside the pvc glowing. Are these the energies we are looking to be working with?  ;]
Mags
semenihin-77
The main fallacy of all this is over Specific unit.
This pump, and no more.
The pump receives the potential of the land.
This potential should be enhanced shock.
See patent Kapanadze.
Hope
What an excellent man we have here,  he is giving all his help.   Thank you Sem 77   Thank you all for this opportunity, it makes a great Christmas project.
I would like to take this moment to wish you all at OverUnity.com a Merry Christmas season.
Richard Williams
"With God, nothing is impossible".
