0 Members and 205 Guests are viewing this topic.
Magluvin
Energia said   (quotes not working Stefan)
proove it , your shema is incorrect, and this is not overunity.
Cmon Energia, its only been a couple days, and he is giving info quite quickly.
Give it a bit of time before demands(that always come) are made.
Thanks Sem for showing..
My first impression was that you connected the light to the copper split pipe as you have shown for the inverter.
In my pics a page back or 2, shows my TC with a single turn at the top lighting a small 12v lamp. Havnt tried introducing a core yet.
If I remember, adding the lamp at the top of the sec didnt increase the input. I suppose that the open ended sec induces the current in the split pipe with the core.
Sem, do you believe that the primaries are inducing the split pipe directly, or as I think?  ;]   Or, does the sec just guide the primary fields to the core?
Hope that makes sense.
I got my TC out of boxes and will try some things this week.  ;]
Thanks again
Mags
verpies
Quote from: jbignes5 on December 05, 2011, 09:39:18 AM
So the electric field means nothing to you???
It does, however the Observer was not asking about that.
I stay focused on topics.
So what if one coil was shorted and the other is used for the signal? Induction would act on the shorted coil much the same as a magnet would.
There would be a force interaction between the signal coil and unenergized shorted ideal coil but it would not be the same, since the signal coil could not attract the shorted coil. The interaction would be akin to diamagnetic only.
The energy in magnets are not given to them by mother nature unless they are natural magnets from the ground. A good majority of the magnets are nothing more then man made alignments.
That's why I wrote:
  The energy in the magnet:
     1) has been given to it by mother nature (electron/nuclei spin alignment within ferromagnetic domains)
     2) hidden by mother nature through domain randomization
     3) unhidden by the magnet factory where the magnet was permanently magnetized (unrandomized, ordered domains).
Again if magnets used heavy current magnetic fields then where is all this heavy current coming from?
The word "if" implies that I have stated that "magnets use heavy current magnetic fields".  This is a false implication, most likely resulting from the imprecise interpretation of my statement regarding the equivalence of free and bound currents in matter.   See the attachment in my previous post.
I would say that a magnet is actually an electric field holder. The magnetic field is held up by this electric field and could not exist without it in the case of the magnet.
That statement is not always true because it is ambiguous. It allows for static electric fields and is well known and observed that invariant electric fields do not produce magnetic phenomena. (but time variant or spatially variant electric fields, do).
If you stated that a magnet is a holder of electric current (moving electric charges) or intrinsic electron spins, then I might have agreed.
In reality our science does not even have a good conceptual understanding of what electron is (it is treated axiomatically) and how it can have a spin being a point particle.  I met only one guy in my life that had a grasp of these basic concepts.
Anyway, I do not wish to discuss these theoretical matters any further on this forum (elsewhere yes) as they are a distraction from the issues of practical engineering and measurements of these interesting devices.
P.S.
Merely lighting a light bulb and sparking is not interesting.
yfree
Quote from: semenihin-77 on December 05, 2011, 12:14:42 PM
Delamorto scheme works!
It was an accident due to overclocking Kacher, but the result has been obtained!
Delamorto,
Did you try самозапиÑ,ку (self-powering) with the inverter?
Did it blow up? Please be careful.
Thank you.
jbignes5
I think you are thinking in the wrong fields there. The Tesla coil works with voltages only the current is handled by the exciter coil. This orients the electric field and concentrates it into the ferrite from it's respected 90 degrees. The one turn coil is the best way to interact with this field. If you pulse the 1 turn it would be very very high in current. Even though the current last entirely shorter of a time. The current is at max but the time it takes to fire is way less. The transfer method is inductive via the 1 wire going up the inside of the 1 turn coil. The ferrite amplifies this induction and the Tesla coil picks this up and converts it into a higher voltage just like the external coil does. Because the 1 turn coil is the inductive receiver it isn't directly connected to the circuit but still gets all the current and funnels it out the ends for the heavy magnetic pulse. Because the 1 turn coil has a slot in it, it broadcasts a beam into the Tesla coil causing a conversion into high voltage rejoining the process.
Someone asked awhile ago iof the exciter type of devices were this energy we are interested in and to tell the truth yes it is. The blue fire or jets being emitted from these type of devices is exactly what we want to play with and it has been shown that there is a force involved with the streamers that get emitted from the ends of the small wires. Tesla first found this event when playing with unconnected conical coils that were not connected in any way with the transmitter. They were oriented radiating outwards from the point of origin and the wide end was inwards. He said the jets were not from the wire that it seemed they were from around the wire but the wire focused and directed the flows of pulses from the emitter device.
