0 Members and 270 Guests are viewing this topic.
semenihin-77
Quote from: energia9 on December 05, 2011, 12:18:42 PM
proove it , your shema is incorrect, and this is not overunity.
inverter consumes 15 watts, traf iron just will not give more power. Kacher consumption 20 watts, it was demonstrated yesterday.
2 bulbs of 60 watts = 35 watts?
znel
Quote from: semenihin-77 on December 05, 2011, 02:01:27 PM
I can verify that what semenihin-77 is doing works.   I have a similar set up that I put together last year and have worked with it on and off over the time.   Verifying the actual output would be the only way of proving one way or the other that it is or isn't in fact overunity.   Bulbs are a good visual representation of work being done but do not represent the actual output.   Just because they are rated at 60 watts in a conventional circuit doesn't mean they are using 60 watts to light.  This method of output is deceiving.
semenihin-77
Quote from: znel on December 05, 2011, 02:43:59 PM
To do so, and publish. Everything is open and honestly, as it is.
Collect the device and check its operation.
energia9
Quote from: semenihin-77 on December 05, 2011, 02:48:24 PM
are you delamorto?
ramset
If you want to stop guessing how much power you are making
Do this..............
If you have any questions PM me I will be glad to assist you in Proper technique
You will know in one half hours time if you have something special going on !!
You are looking at a light bulb Immersed in one liter of water [no the metal part is not in the water]
it is running through a Killowatt meter.
Run the test until you get One Tick on the meter,... measure the time and the temp of the water  this will be your baseline
Know plug your device into the meter ,Place the bulb {properly] into the vessel
Repeat test...................
Compare Notes
Simple
Good luck
Chet
PS
If you stick to heating one liter, you will have tons of published test data to reference!
Thanks Grandma
