0 Members and 43 Guests are viewing this topic.
xenomorphlabs
Can anyone recommend a good site to find replacement/equivalent  transistors?
@Magluvin: What transistor type did you use?
I got a couple of russian transistors but not the KT805AM.
It has an ftrans of 20 MHz and most of the other transistors i come across
only have like 1-3 MHz and a power rating of 30 Watt.
Acca
T-1000
Quote from: semenihin-77 on December 05, 2011, 12:14:42 PM
Delamorto scheme works!
It was an accident due to overclocking Kacher, but the result has been obtained!
EDIT: Apparently I got wrong person...
I contacted Delamorto about this. He said he is not responsible for this circuit. So who is behind of it? :)
Kator01
Hey wattsup,
concerning your idea of the parallel stripes I would expect them to destroy themselfs if you do not have them strongly glued on a epoxy-sheet. There might show up heavy current-density
http://www.youtube.com/watch?v=6uSKFmgmQvs
Kator01
energia9
Quote from: ramset on December 05, 2011, 03:14:15 PM
If you want to stop guessing how much power you are making
Do this..............
If you have any questions PM me I will be glad to assist you in Proper technique
You will know in one half hours time if you have something special going on !!
You are looking at a light bulb Immersed in one liter of water [no the metal part is not in the water]
it is running through a Killowatt meter.
Run the test until you get One Tick on the meter,... measure the time and the temp of the water  this will be your baseline
Know plug your device into the meter ,Place the bulb {properly] into the vessel
Repeat test...................
Compare Notes
Simple
Good luck
Chet
PS
If you stick to heating one liter, you will have tons of published test data to reference!
You are 10000% right!
im open to newer simple possiblities to overunity devices, but without delamroto or semenh showing real time measurements, we are unable to be sure , i hope you understand it dear Semenh,
if you show us scope shot, and (or) RAMSET  technique, we will see wether its worth investigating, or not.
power from mains: put 60 watt light bulb in water,            Time:                 Temperature:
Power from coil device: put 60 watt light bulb in water       Time:                Temperature:
Time to heat up in comparison with mains and coil device  to a certain temperature ,  say  50C
Water should be started from the same temperature in same bowl with same bulb.
cool down bowl for each measuring to room temperature
